QuickWin Internal Errors
coder
Hy!
I am using Compaq Visual Fortran 6.6.a, and when I am
runningQuickWin application I am getting this two
"QuickWin Internal Error"s:
-file: "E:forrtluildqwnbuildqwgsvid.c", line 614
and after that error
- file: "E:forrtluildqwnbuildqwgswc.c", line 636
After that two errors, program normaly continuoes.
(With QWIN, I am using PGPLOT graphic library.)
Robert Vertnik
washer
We encounter the same problem in one of our application.
If you found the solution with your problem, could you forward it to us?
