RESHAPE() and 3 dimensional array
gelarimer
I am trying to create a 3 dimensional array with RESHAPE() but get the following error message:
Error: The size of SOURCE must be greater than or equal to PRODUCT(SHAPE). [RESHAPE].
I have counted the number of elements in the Source array and they total 150 (6x5x5 = 150), and
PRODUCT(Shape) = 6x5x5 = 150 so I am stumped.
The code is posted below. Any comments would be appreciated.
[plain]MODULE JShift
! MODULE contains J Shift values for diagonal interpolation
IMPLICIT NONE
! the following J shift data is from the following spreadsheet:
! IVF WIN32 SeriesScanned SeriesGawn Burrill"GB Max Kt & Kq shift.xls"
REAL(4), PARAMETER, DIMENSION(6,5,5) :: GBD_JShift = &
     RESHAPE(SOURCE = (/ &
     !Prop 306 thru 320  BAR = 0.5
     ! Sig 2.0	Sig 1.5	  Sig 1	   Sig  0.75	Sig 0.5     P/D Range
       0.105,   0.190,    0.150,   0.130,       0.170, &    ! 0.6 to 0.8
       0.095,   0.110,    0.210,   0.230,       0.195, &    ! 0.8 to 1.0
       0.080,   0.100,    0.115,   0.175,       0.160, &    ! 1.0 to 1.2
       -1.0,     -1.0,    -1.0,    -1.0,        -1.0,  &    ! 1.2 to 1.4
       -1.0,     -1.0,    -1.0,    -1.0,        -1.0,  &    ! 1.4 to 1.6
       0.375,    0.400,   0.505,   0.520,       0.640, &    ! 1.2 to 2.0
     !Prop 406 thru 420  BAR = 0.65
       0.075,    0.110,   0.170,   0.150,       0.185, &    ! 0.6 to 0.8
       0.100,    0.100,   0.135,   0.180,       0.175, &    ! 0.8 to 1.0
       0.075,    0.090,   0.105,   0.150,       0.130, &    ! 1.0 to 1.2
       0.095,    0.105,   0.130,   0.140,       0.185, &    ! 1.2 to 1.4
       0.085,    0.085,   0.090,   0.125,       0.095, &    ! 1.4 to 1.6
       0.170,    0.195,   0.235,   0.220,       0.335, &    ! 1.6 to 2.0
     ! Prop 106 thru 120  BAR = 0.80
       0.100,    0.100,   0.145,   0.165,       0.140, &    ! 0.6 to 0.8
       0.085,    0.105,   0.140,   0.160,       0.160, &    ! 0.8 to 1.0
       0.090,    0.090,   0.095,   0.125,       0.170, &    ! 1.0 to 1.2
       0.085,    0.100,   0.120,   0.115,       0.145, &    ! 1.2 to 1.4
       0.095,    0.100,   0.110,   0.130,       0.120, &    ! 1.4 to 1.6
       0.155,    0.160,   0.185,   0.215,       0.245, &    ! 1.6 to 2.0
     ! Prop 508 thru 520  BAR = 0.95
       -1.0      -1.0,    -1.0,    -1.0,        -1.0,  &    ! 0.6 to 0.8
       0.095,    0.100,   0.115,   0.130,       0.150, &    ! 0.8 to 1.0
       0.095,    0.085,   0.090,   0.100,       0.135, &    ! 1.0 to 1.2
       0.095,    0.110,   0.130,   0.150,       0.125, &    ! 1.2 to 1.4
       0.095,    0.090,   0.080,   0.105,       0.150, &    ! 1.4 to 1.6
       0.160,    0.190,   0.230,   0.205,       0.230, &    ! 1.6 to 2.0
     ! Prop 208 thru 216  BAR = 0.95
       -1.0,    -1.0,     -1.0,    -1.0,        -1.0,  &    ! 0.6 to 0.8
       0.085,   0.100,    0.110,   0.130,       0.170, &    ! 0.8 to 1.0
       0.125,   0.090,    0.105,   0.090,       0.125, &    ! 1.0 to 1.2
       0.085,   0.125,    0.105,   0.120,       0.125, &    ! 1.2 to 1.4
       0.115,   0.075,    0.100,   0.125,       0.155, &    ! 1.4 to 1.6
       -1.0,    -1.0,     -1.0,    -1.0,        -1.0/),&    ! 1.6 to 2.0
     SHAPE = (/6,5,5/), ORDER = (/2,1,3/))
END MODULE[/plain]
JVanB
Valued Contributor II
[cpp]       -1.0      -1.0,    -1.0,    -1.0,        -1.0,  &    ! 0.6 to 0.8
[/cpp]
gelarimer
Thanks Repeat Offender! Can not believe I missed the missing comma. I went over those numbers several times looking forjust such a problem.Maybe I need to enlarge the type on thescreen. Added the comma and the Module compiled with no error. Thank youmuch.
