RESHAPE and order argument
gelarimer
TheORDER = (/2,1,3/)argument in the RESHAPE() intrinsic function below does notappear to work or is being ignored.I would like the array GBD_JShift() to look like the layout of the numbers in the code below, but what I am getting is col. 1 is being filledfirst, then col. 2, then col. 3 and so on as ifORDER = (/1,2,3/) is being used.
Any information or comments would be appreciated. Thanks
[plain]MODULE JShift
! MODULE contains Delta J AVG values for diagonal interpolation
IMPLICIT NONE
! Delta J Avg data is from the following spreadsheet:
! IVF WIN32 SeriesScanned SeriesGawn Burrill"GB Max Kt & Kq shift.xls"
REAL(4), PARAMETER, DIMENSION(6,5,5) :: GBD_JShift = &
     RESHAPE(SOURCE = (/ &
     !Prop 306 thru 320  BAR = 0.5
     ! Sig 2.0	Sig 1.5	  Sig 1	   Sig  0.75	Sig 0.5     P/D Range
       0.105,   0.190,    0.150,   0.130,       0.170, &    ! 0.6 to 0.8
       0.095,   0.110,    0.210,   0.230,       0.195, &    ! 0.8 to 1.0
       0.080,   0.100,    0.115,   0.175,       0.160, &    ! 1.0 to 1.2
       -1.0,     -1.0,    -1.0,    -1.0,        -1.0,  &    ! 1.2 to 1.4
       -1.0,     -1.0,    -1.0,    -1.0,        -1.0,  &    ! 1.4 to 1.6
       0.375,    0.400,   0.505,   0.520,       0.640, &    ! 1.2 to 2.0
     !Prop 406 thru 420  BAR = 0.65
       0.075,    0.110,   0.170,   0.150,       0.185, &    ! 0.6 to 0.8
       0.100,    0.100,   0.135,   0.180,       0.175, &    ! 0.8 to 1.0
       0.075,    0.090,   0.105,   0.150,       0.130, &    ! 1.0 to 1.2
       0.095,    0.105,   0.130,   0.140,       0.185, &    ! 1.2 to 1.4
       0.085,    0.085,   0.090,   0.125,       0.095, &    ! 1.4 to 1.6
       0.170,    0.195,   0.235,   0.220,       0.335, &    ! 1.6 to 2.0
     ! Prop 106 thru 120  BAR = 0.80
       0.100,    0.100,   0.145,   0.165,       0.140, &    ! 0.6 to 0.8
       0.085,    0.105,   0.140,   0.160,       0.160, &    ! 0.8 to 1.0
       0.090,    0.090,   0.095,   0.125,       0.170, &    ! 1.0 to 1.2
       0.085,    0.100,   0.120,   0.115,       0.145, &    ! 1.2 to 1.4
       0.095,    0.100,   0.110,   0.130,       0.120, &    ! 1.4 to 1.6
       0.155,    0.160,   0.185,   0.215,       0.245, &    ! 1.6 to 2.0
     ! Prop 508 thru 520  BAR = 0.95
       -1.0,     -1.0,    -1.0,    -1.0,        -1.0,  &    ! 0.6 to 0.8
       0.095,    0.100,   0.115,   0.130,       0.150, &    ! 0.8 to 1.0
       0.095,    0.085,   0.090,   0.100,       0.135, &    ! 1.0 to 1.2
       0.095,    0.110,   0.130,   0.150,       0.125, &    ! 1.2 to 1.4
       0.095,    0.090,   0.080,   0.105,       0.150, &    ! 1.4 to 1.6
       0.160,    0.190,   0.230,   0.205,       0.230, &    ! 1.6 to 2.0
     ! Prop 208 thru 216  BAR = 0.95
       0.085,   0.100,    0.110,   0.130,       0.170, &    ! 0.8 to 1.0
       0.125,   0.090,    0.105,   0.090,       0.125, &    ! 1.0 to 1.2
       0.085,   0.125,    0.105,   0.120,       0.125, &    ! 1.2 to 1.4
       0.115,   0.075,    0.100,   0.125,       0.155, &    ! 1.4 to 1.6
       -1.0,    -1.0,     -1.0,    -1.0,        -1.0/),&    ! 1.6 to 2.0
     SHAPE = (/6,5,5/), ORDER = (/2,1,3/))
END MODULE[/plain]
gelarimer
The following code produces array Test1() which is identical to array Test2() even though the ORDER argument in the intrinsicRESHAPE() is different.
What am I doing wrong? Thanks for any comments.
[plain]SUBROUTINE Test()
IMPLICIT NONE
REAL(4) ret1, ret2
REAL(4), DIMENSION(2,2,2) :: Test1 = RESHAPE( SOURCE = (/1.0,2.0,3.0,4.0,5.0,6.0,7.0,8.0/), &
         SHAPE = (/2,2,2/), ORDER = (/1,2,3/))
REAL(4), DIMENSION(2,2,2) :: Test2 = RESHAPE( SOURCE = (/1.0,2.0,3.0,4.0,5.0,6.0,7.0,8.0/), &
         SHAPE = (/2,2,2/), ORDER = (/2,1,3/))
       ret1 = Test1(2,1,1)
       ret2 = Test2(2,1,1)
       RETURN
end[/plain]
I agree this looks odd - I'll investigate.
anthonyrichards
New Contributor III
Are you using IVF or Compaq Visual Fortran?
Using CVF, Iget the same as you , (1,2,3,4,5,6,7,8) with ORDER = (/2,1,3/) instead of the desired (1,5,3,7,2,4,6,8).
Using ORDER = (/3,2,1/) (i.e. C-ordering) I get Test2=(1,5,3,7,2,6,4,8) as desired.
BUTusing ORDER = (/1,3,2/) I get Test2=(1,1,3,3,2,2,4,4) instead of the desired (1,2,5,6,3,4,7,8)
Using IVF, I get the same as you , (1,2,3,4,5,6,7,8) with ORDER = (/2,1,3/) instead of the desired (1,5,3,7,2,4,6,8).
BUT using ORDER = (/1,3,2/) I get Test2 =(1,2,5,6,3,4,7,8), as desired.
So it looks like CVF had bugs withRESHAPE,and IVF stillhas RESHAPE bugs, but one less than CVF!
I would guess that most effort was concentrated on getting the C-re-ordering right, at the expense of all others.
gelarimer
Thanks Anthony and Steve, I am using IVF.
I reported this as a bug to development.
It turns out that this problem exists only for use of RESHAPE in initialization expressions. If you put it in executable code, such as an assignment statement, it works fine.
This bug is scheduled to be fixed in a future update to version 11.1 (probably August.)
This problem was corrected in 11.1 Update 2.
