Range between two dates
kooka
I have two date, each one in a FILETIME structure,how can I know how much days between this two date?
kooka
I found this code in C, but i dont't undestand at all, because
i can't use memcpy function in fortran. Please, i need help with this
VOID GetTimeDifference(const PSYSTEMTIME pst1, const PSYSTEMTIME pst2, int* piHours, int* piMins, int* piSecs)
static const ULONGLONG FT_SECOND = ((ULONGLONG) 10000000);
static const ULONGLONG FT_MINUTE = (60 * FT_SECOND);
static const ULONGLONG FT_HOUR = (60 * FT_MINUTE);
static const ULONGLONG FT_DAY = (24 * FT_HOUR);
// Convert each SYSTEMTIME structure into a FILETIME one...
FILETIME ft1, ft2;
SystemTimeToFileTime(pst1, &ft1);
SystemTimeToFileTime(pst2, &ft2);
// Convert to large integers...
ULARGE_INTEGER li1 = {0};
memcpy(&li1, &ft1, sizeof(FILETIME));
ULARGE_INTEGER li2 = {0};
memcpy(&li2, &ft2, sizeof(FILETIME));
// Subtract the two dates...
ULONGLONG ullNanoDiff = li2.QuadPart - li1.QuadPart;
// FILETIME's measure the number of 100-nanosecond intervals. Convert this to seconds...
long lSecDiff = (long) (ullNanoDiff / FT_SECOND);
// Finally, convert seconds to minutes and hours, if necessary...
*piHours = (int) lSecDiff / 3600;
lSecDiff = lSecDiff % 3600;
*piMins = lSecDiff / 60;
*piSecs = lSecDiff % 60;
joerg_kuthe
I don't have a solution for your problem but I have a routine which might help you to work with Windows' FILETIME and SYSTEMTIME structures. There is a bit of German in it:
Zeit = time
deutsch = German
I hope this helps you somewhat.
Jrg Kuthe
www.qtsoftware.de
SUBROUTINE qtConvertFileTimeToSystemTime( FT, ST, iLanguage, strZeit )
! converts 64 Bit Filetime (in FT) into system time.
USE DFWINTY
IMPLICIT NONE
TYPE (T_FILETIME), INTENT(IN):: FT
TYPE (T_SYSTEMTIME), INTENT(OUT) :: ST
INTEGER, INTENT(IN):: iLanguage ! 1: deutsch, 2: english
CHARACTER (*), INTENT(OUT) :: strZeit ! LEN(strZeit) > 27 erforderlich
 INTEGER iRet
CHARACTER (3) :: c3DayOfWeek(2,0:6) = (/'So', 'Sun', 'Mo', 'Mon', &
'Di', 'Tue', 'Mi', 'Wed', &
'Do', 'Thu', 'Fr', 'Fri', 'Sa', 'Sat' /)
 INTERFACE
FUNCTION FileTimeToSystemTime( lpFileTime, lpSystemTime )
USE DFWINTY
integer(BOOL) :: FileTimeToSystemTime ! BOOL
!DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'FileTimeToSystemTime' :: FileTimeToSystemTime
!DEC$ ATTRIBUTES REFERENCE, IGNORE_LOC, ALLOW_NULL :: lpFileTime
TYPE (T_FILETIME) lpFileTime ! FILETIME* lpFileTime
!DEC$ ATTRIBUTES REFERENCE, IGNORE_LOC, ALLOW_NULL :: lpSystemTime
TYPE (T_SYSTEMTIME) lpSystemTime ! LPSYSTEMTIME lpSystemTime
END FUNCTION
END INTERFACE
IF ( LEN(strZeit) < 28 ) RETURN
iRet = FileTimeToSystemTime( FT, ST )
 IF ( iLanguage == 1 ) THEN
WRITE (strZeit, 10000)c3DayOfWeek(iLanguage, ST % wDayOfWeek), &
ST % wDay, ST % wMonth, ST % wYear, &
ST % wHour, ST % wMinute, ST % wSecond, ST % wMilliseconds
10000 FORMAT(A2, 1X, 2(I2.2, '.'), I4, 1X, 3(I2.2, ':'), I4.4)
ELSE IF( iLanguage == 2 ) THEN ! english
ST % wMonth, ST % wDay, ST % wYear, &
10010 FORMAT(A3, 1X, 2(I2.2, '.'), I4, 1X, 3(I2.2, ':'), I4.4)
ELSE
RETURN
END IF
RETURN
END
Paul_Curtis
Valued Contributor I
Here is a routine to convert ymd values, which can be obtained from components of a T_SYSTEMTIME, into an integer representation as a Julian date; the interval between any two Julian dates is simply their integer difference.
FUNCTION julian_date (yyyy, mm, dd) RESULT (julian)
IMPLICIT NONE
! converts calendar date to Julian date
! cf Fliegel & Van Flandern, CACM 11(10):657, 1968
! example: julian_date(1970,1,1)=2440588
INTEGER,INTENT(IN) :: yyyy,mm,dd
INTEGER :: julian
julian = dd - 32075 + 1461*(yyyy + 4800 + (mm - 14)/12)/4 + &
367*(mm - 2 - ((mm - 14)/12)*12)/12 - &
3*((yyyy + 4900 + (mm - 14)/12)/100)/4
END FUNCTION julian_date
kooka
tanks for your help buddies,I can't reply you before,I had problems with internet.but I was wondering if those formulas can help me with dates before 1971?
I was wondering too what happens if I substract each one of the fields of the filetime structure. i.e. date1 = filetime2%dwLowDateTime - filetime1%dwLowDateTime or date2 = filetime2%dwHighDateTime - filetime1%dwHighDateTime.Does any of these values( date1, date2) , give me the correct number of days between the two dates? or I'm lost?
I copy the help in the MSDN help abuot filetime struct.
var ArrowOffPath="http://i.msdn.microsoft.com/Platform/Controls/DropDownFilter/resources/arrow-off.gif"; var ArrowOnPath="http://i.msdn.microsoft.com/Platform/Controls/DropDownFilter/resources/arrow-on.gif"; var strConstLangFilterAll ="All"; var strConstLangFilterMulti ="Multiple"; var strConstLangFilterNone ="None"; var strConstLangFilterText ="Language Filter"; var oMTPS_DD_ImgArrow = document.getElementById("ctl00_LibFrame_ddfPlaceHolder_MTPS_DD_ImageArrow"); var oMTPS_DD_PanelLink = document.getElementById("ctl00_LibFrame_ddfPlaceHolder_Mtps_DropDownFilterText"); var oMTPS_DD_Div = document.getElementById("ctl00_LibFrame_ddfPlaceHolder_DropDownFilterMain"); var oMTPS_DD_PopUpDiv = document.getElementById("ctl00_LibFrame_ddfPlaceHolder_Mtps_DropDownPopUp");
FILETIME Structure
Contains a 64-bit value representing the number of 100-nanosecond intervals since January 1, 1601 (UTC).
Syntax
typedef struct _FILETIME {
DWORD dwLowDateTime;
DWORD dwHighDateTime; } FILETIME,
*PFILETIME;
Members
dwLowDateTime
The low-order part of the file time.
dwHighDateTime
The high-order part of the file time.
Remarks
To convert a FILETIME structure into a time that is easy to display to a user, use the FileTimeToSystemTime function.
It is not recommended that you add and subtract values from the FILETIME structure to obtain relative times. Instead, you should copy the low- and high-order parts of the file time to a LARGE_INTEGER structure, perform 64-bit arithmetic on the QuadPart member, and copy the LowPart and HighPart members into the FILETIME structure.
Do not cast a pointer to a FILETIME structure to either a LARGE_INTEGER* or __int64* value because it can ca use alignment faults on 64-bit Windows.
Paul_Curtis
IVF provides an interface to the Windows
function FileTimeToSystemTime which
does exactly what its name promises. You
can then build a Julian date from the systemtime
components. The Julian formula works with
any date after 1/1/0000, but you are unlikely
to encounter filetimes from 1971, since this
predates personal computers by about 10
years.
kooka
HI, FOR SOME REASON THE JULIAN DATE FUNCTION DOESN'T WORK WELL WHITH ME, I THINK IT WORKS WELL BUT, INSTEAD I CAN RESOLVE MY PROBLEM BY OTHER WAY, IT IS BY CREATING A UNION IN THIS WAY:
type numero
union
map
integer*4 lw, hw
end map
map
integer*8 qp
end map
end union
end type
I COPY TWO PARTS OF THE FILETIME STRUCTURE IN THE LW AND HW PARTS OF MY UNION, AND THE QP PART RETURNS THE JOINED INTEGER. THEN I CAN DO OPERATIONS TO GIVE METHE NUMBER OF DAYS.
SO TANKS FOR YOUR HELP, I POST THIS BECAUSE CAN BE ANOTHER WAY TO HELP YOUIF YOU HAVETHIS PROBLEM.
