29647 Discussions
Re: Array Visualizer problem with XP Service Pack 1
Intel_C_Intel
I'm running XP SP1 on my machine, and haven't seen any problems with using Compaq AV.
Perhaps there is a problem with a driver on your machine. Some drivers are more XP-compatible than others. If you run Array Viewer from the start menu, does it work normally?
John
Intel_C_Intel
That's certainly odd. If you learn anything more, please let us know.
John
