Re-size array within a subroutine
sang186
I am trying to implement a push_back routine as below.
SUBROUTINE push_back(array, val)
    INTEGER,DIMENSION(:), ALLOCATABLE :: tmp_arr
    INTEGER, DIMENSION(:) :: array
    INTEGER val
    ALLOCATE(tmp_arr(0 : SIZE(array)))
    tmp_arr(0:(SIZE(array)-1))=array
    tmp_arr(SIZE(array)) = val
    DEALLOCATE(array)
    ALLOCATE(array(0:SIZE(tmp_arr)-1))
    CALL move_alloc(tmp_arr, array)
END SUBROUTINE push_back
On resizing an allocatable array (declared ALLOCATABLE in the calling subroutine) , I get the following compile errors
  • error #6724: An allocate/deallocate object must have the ALLOCATABLE or POINTER attribute. [ARRAY]
  • error #8195: The argument to the MOVE_ALLOC intrinsic subroutine shall be an allocatable object. [MOVE_ALLOC]
I want the resize to work such that the data that is passed is not lost. However, by making array ALLOCATABLE within the subroutine , I would lose the existing data.
Any help with this would be great.
mecej4
Merely declaring an argument array to be ALLOCATABLE does not change its allocation status or contents. The following program works fine [fortran] program tpush IMPLICIT NONE INTEGER, DIMENSION(:), ALLOCATABLE :: ivec INTEGER :: val=4 ALLOCATE(ivec(3)) ivec=(/1,2,3/) call push_back(ivec, val) write(*,'(10I4)')ivec contains SUBROUTINE push_back(array, val) INTEGER,DIMENSION(:), ALLOCATABLE :: tmp_arr INTEGER, DIMENSION(:),ALLOCATABLE :: array INTEGER val ALLOCATE(tmp_arr(0 : SIZE(array))) tmp_arr(0:(SIZE(array)-1))=array tmp_arr(SIZE(array)) = val DEALLOCATE(array) ALLOCATE(array(0:SIZE(tmp_arr)-1)) CALL move_alloc(tmp_arr, array) END SUBROUTINE push_back END PROGRAM tpush [/fortran] The program prints out [bash] 1 2 3 4[/bash] [Complaints re ISDN forum software: (i) The program source code above appears single-spaced in edit mode, but appears mostly double spaced in browse mode; (ii) It is confusing when the OP replies to other people's responses and there are no response numbers to provide information on which response is being replied to .]
Les_Neilson
Valued Contributor II
INTEGER, DIMENSION(:), ALLOCATABLE :: array you forgot to tell the compiler that "array" was also allocatable. Les
A__Valle
Is this something that you want to reach? SUBROUTINE UTIL_ADDTO_ARRAYint2Allocarray(ToBeAdded,IntegerArray) !{ ! This subroutine adds a single value to the end of an integer array. IMPLICIT NONE !** HEADER VARIABLES/ARGUMENTS INTEGER, INTENT(IN) ::ToBeAdded INTEGER, ALLOCATABLE ::IntegerArray(:) !***************************************************************************** !** LOCAL VARIABLES INTEGER ::NewSize INTEGER ::OldSize INTEGER, ALLOCATABLE ::CopyArray(:) !************************************************************************* IF (allocated(IntegerArray)) THEN OldSize=size(IntegerArray) NewSize = OldSize + 1 ALLOCATE(CopyArray(NewSize)) CALL MOVE_ALLOC(CopyArray, IntegerArray) IntegerArray(NewSize) = ToBeAdded ELSE ALLOCATE(IntegerArray(1)) IntegerArray(1)=ToBeAdded ENDIF ENDSUBROUTINE UTIL_ADDTO_ARRAYint2Allocarray !} Making the array allocatable within the subroutine does not lose your data. regards, Dirk
sang186
On making array 'ALLOCATABLE ' with INTEGER, DIMENSION(:), ALLOCATABLE :: array I would lose its existing allocation and its data and I would like to retain that.
sang186
Sorry, It was my bad. I had overlooked the allocation of the array with a zero index in the calling function . It works now. @Les & @Dirk - Thank you very much for the inputs. Sangeetha
sang186
It was totally my bad. Thank you very much, mecej4.
mecej4
Les_Neilson
That's ok - we all make mistakes. Glad it now works Les
