Read Statement
erheiqin
I am using read statement to read data from file, which contains data as types as 1 0.845149. I want to read these data into real numbers. What is the right format to do here? I tried many different ways. I could not get it.
Erhei
Jugoslav_Dujic
Valued Contributor II
Use either list-directed input ("don't care about format"):
READ(11, *) F1, F2
or use "zero-precision" with F edit descriptor. Note that this is actually preferred method to read reals, as it does not care where the decimal point is actually located in the file:
READ(11, "(F3.0, F10.0)") F1, F2
Jugoslav
