Read a string like read a file?
haitao
I have a old program reading a text file line by line. the code is like this:
character*80 line
open (4, file = 'myfile.txt')
do while (n .eq. 0)
read(4,'(80a)',end = 9999) line
callmysub(line)!do something for line
end do
9999
n = -1
Now, a long string is passed here instead of myfile.txt. I want to do this:
character*(80) line
character*(10000)input_str
do while (n .eq. 0)
read(input_str, '(80a)',end = 9999) line
end do
9999
n = -1
The problem is it always start to readat beginning of the input_str, then the line is always the same.
Is there any way to control the position of read like read a file?
hhtlib
anthonyrichards
New Contributor III
You need to keep track of where you are in read input_str after each read.
You also should initialise 'line' to blanks before each read, otherwise reading the last section that is not exactly 80 characters long will leave characters from the previous read in the locations that are not overwritten. One suggestion is, if 'numchars' is the number of characters to be read each time:
integer numchars, len_input, numreads, iread, istart, iend
character*80 line, blankline
blankline=adjustl(adjustr(blankline))
numchars=80
len_input=len_trim(input_str)
numreads=(len_input+numchars-1)/numchars
istart=1
iend=numchars
if(numreads>0) then
do iread=1,numreads
line=blankline
read(input_str(istart:iend), '(80a)',end = 9999) line
istart=istart+numchars
iend=iend+numchars
end do
endif
haitao
I'll try.
This forum is so good and the people are so nice.
hhtlib
