Read file error in Fortran DLL
pradeepnatekar
What is the default directory path when there are readfile statements in fortran dll created.
I get error of "Filed to open xxxx file for reading" even if the files are there in same directory where dll is located.
Pradeep
anthonyrichards
New Contributor III
If it is a DLL, you must be calling it by running an .EXE first, so the file you need to
access should probably be in the same directory as the .EXE that calls the DLL (or calls a DLL that calls the DLL in question).
