Read registry
bjornk
I like to get a sample Visual Fortran code to read an entry in the Registry. Could anyone suply me with example code ?
rahzan
I wrote this routine to set an environment variable.
Shows you all the elements. If you just want to read things, you'll use RegOpenKeyEx followed by RegQueryValueEx
No guarantees!!!
Tim
subroutine setEnvVar(valName,valData,ierr)
use dfwin
implicit none
character*(*),intent(inout)::valName
character*(*),intent(inout)::valData
integer(2), intent(out):: ierr
character(100) subKey
integer(LONG) regCallStat, hNewOrOld, mainKey
integer(LONG) hKey , valLen,valType
integer i
ierr=-1
! use these for the current user environment
! "For the system level env variables there are 2 keys to set. Only different in their subKey"
! MSsupp says it is NOT necessary to change the "ControleSetxxx" as windows will write this on its own.
! hence the loop below could be disabled
mainKey= HKEY_LOCAL_MACHINE
subkey='SYSTEMCurrentControlSetControlSession ManagerEnvironment'C
valName=trim(valName)//char(0)
valLen=len_trim(valData)
valData=valData(:valLen)//char(0)
valType=REG_SZ
do i=1,2
regCallStat=RegCreateKeyEx(mainKey, loc(subKey), 0,'REG_SZ'C, &
REG_OPTION_NON_VOLATILE, KEY_ALL_ACCESS, NULL, loc(hKey), &
loc(hNewOrOld))
if(regCallStat)return
regCallStat=RegSetValueEx(hKey, valName, 0, valType, loc(valData), valLen)
if(regCallStat)ierr=-1
regCallStat=RegCloseKey(hKey)
subKey='SYSTEMControlSet001ControlSession ManagerEnvironment'C !first subkey
! l=len_trim(subKey)+1
! subKey(l:l)=char(0)
enddo
ierr=0
end subroutine setEnvVar
bjornk
I tried the code below but it fails.
c I wrote this routine to set an environment variable.
c Shows you all the elements. If you just want to read things,
c you'll use RegOpenKeyEx followed by RegQueryValueEx
c No guarantees!!!
c
c ===============================
subroutine ReadRegVar(valName,valData,ierr)
use dfwin
implicit none
integer i
ierr=-1
subkey='SOFTWARESysdecoGINIS VisionPath'S
valType=REG_SZ
regCallStat=RegOpenKeyEx(mainKey,subKey,0, KEY_ALL_ACCESS,
+ loc(hKey))
ierr=0
end subroutine ReadRegVar
The return value from RegOpenKeyEx is 2.
Please help
Jugoslav_Dujic
Valued Contributor II
Error 2 is ERROR_FILE_NOT_FOUND, i.e. non-existing path. See "System errors - Numerical Order" help topic.
What's the S on the end? It's supposed to be C? Besides, "Path" looks suspicious to me -- is it a key ("folder") or a value ("file")? If the latter, you have to use RegQueryValue[Ex] on it after.
Jugoslav
Jugoslav_Dujic
Additional side note: do not use KEY_ALL_ACCESS on HKEY_LOCAL_MACHINE (HKLM). On most NT systems with decent security, HKLM is read-only for all users but administrators; it should be written by setup program and just read by applications. If you want just to read from it, use KEY_QUERY_VALUE access; or use HKEY_CURRENT_USER instead. (But that's not your current problem, since you would have got ERROR_ACCESS_DENIED=5).
bjornk
Finally I got it to work. I attach the code.
subroutine ReadRegVar(skey,valData,valname,mode,ll,ierr)
use dfwin
implicit none
character*(*),intent(inout)::skey
character*(*),intent(inout)::valdata
character*(*),intent(inout)::valname
integer*4, intent(inout):: mode
integer*4, intent(out):: ll
integer*4, intent(out):: ierr
character*255 subKey, vname, strx
integer*4 regCallStat, mainKey, hKey, l1, l2
ierr = 0
if (mode .eq. 1) then
else
ierr = -2
return
endif
subkey = skey
regCallStat=RegOpenKeyEx(mainKey,subKey,0, KEY_QUERY_VALUE,
+ loc(hKey))
if (regCallStat .ne. 0) then
ierr = regCallStat
return
endif
vname = valname ! value name
l1 = 0
l2 = 256
regCallStat = RegQueryValueEx (hKey, vname, 0, loc(l1),
+ loc(strx),loc(l2))
ierr = regCallStat
return
endif
ll = l2 - 1 ! strip away null termination
valdata = strx(1:ll)
Many tanks
