29653 Discussions
Reading data without specific format on each line
ZlamalJakub
New Contributor III
I need to read big data file (20MB and greater) like
1 1.0 2334.444e3
100 -1.2356e8 3.13232346
On each line is one integer and two reals, but they can be formatted in different way (length). This file is not generated by me and each user uses different style of file.
I am using
read(10,'(A)') line
read(line,*) i
if (i<=0) then
cycle
endif
read(line,*) i,a,b
First I read file line to variable line to check if the first integer is >0, if not I discard this line
My problem is with last read statement, which is very slow, is there any possibility to set format specification but without length of numbers specified?
Jakub Zlamal
No - the way you're doing it now is really the best approach. What you're asking for is effectively what list-directed is doing for you now.
dannycat
You could try using a 'binary' file to speed up the process. Obviously this depands upon whether you are able to create the file as unformatted yourself.
