Reading file by two programs
gsfantos
Hi there,
is it possible to open a specific file at the same time by two different programs that run simultaneusly and read/write at the same time? The case is direct access and the read-writings are in different lines, but in the same file.
Any suggestions?
George
gsfantos
I did it guys by specifying{/fpscomp:general} in the compiler
Thanks by the way
George
TimP
This is documented in lang_for.pdf under File I/O > OPEN > SHARED.
