29642 Discussions
Redrawing glut window during processing
jaeger0
I have a Quickwinaplication, with a glut driven Window, wher I display something with opengl.
I start a heave computation (Fem_3D), by using a threaded progress bar dialog (Progress). So during computation
the progress bar updates and handls an eventually user stop. So after each progress bar update (IsCancelSignalled) I want to update also the glut window, however It does not work. Either by setting the global variable update, which is handled in the Display_Idle subroutine, nor by directly calling the redraw_window function. The Display_Idle subroutine is only processed if no other process is running, means, we are in the main qickwin loop waiting for an event. So I quess It is something the same with the glutMainLoop. Redrawing works only if I click on the glut window during computation. So glut reacts on userinteraction and really redraws the Windos.
Any Idea how to handle the problem
subroutine FEM_3D(Dlg)
do i=1, 100
call IsCancelSignalled(Dlg,progress,...,stop)
if (stop) then
call Exit_Dialog
return
endif
update = .TRUE.
call redraw_window
.. heavy computations
enddo
end
subroutineIsCancelSiglalled(Dlg, progress,.., stop)
if (stop_button) stop = .TRUE.
retlog =DlgSet(Dlg,IDC_Progress_Bar, progress)
end subroutine
subroutine Progress
hThread =CreateThread(NULL_SA,0,LOC(FEM_3D), Loc(Dlg), o, loc(idThread))
retlog = dlgSetSug(dlg,IDC_PROGRESS_STOP.update_Progress_THREAD)
retlog = DlgModal(Dlg)
end
subroutine Display_IDLE
if (update) call redraw_window
end
subroutine InitDraw
call glutInit
call glutIdleFunc(Display_IDLE)
call glutMainLoop
end subroutine
Program Vsim
call InitDraw
do while(.NOT. VSIM_EXIT)
sleepqq(100)
enddo
end
Paul_Curtis
Valued Contributor I
Quickwin is creating more problems for you than it is solving; you really want to handle your own message loop, which would provide the atomic level of control you need.
That said, the progress-bar control should be run in a single persistent thread created by the main window, not, as shown in your code, by creating a new thread every time the progress-update is called. And you also should use $BeginThreadEx( ) to do this, since CreateThread( ) has a well-documented memory leak.
If you create your own plot window to draw into, then you can send this window an explicit, forcing, redraw message during the computation loop; it is not clear what is accomplished by your calls to "redraw_window", since this function has no argument such as the window handle, which would indicate which window is to be redrawn -- is the plot in the main window, or in a child to the main window? Again, this fuzzy imprecise relation to the actual windows API is the problem with Quickwin.
