29361 Discussions
Regression: Intel Fortran 2025.1 aborting with error #5633: **Internal compiler error
geir
I have a test case where  ifx 2025.1.1 is aborting with "error #5633: **Internal compiler error".  This is a Linux system (both SLES and RHel fail).  This is a REGRESSION, as ifx 2025.0.0. and earlier compilers are able to compile the test without a failure.  I have attached the reduced test case.  Here is the error output:
$ ifx --version
ifx (IFX) 2025.1.1 20250418
Copyright (C) 1985-2025 Intel Corporation. All rights reserved.
$ ifx -c cmp.F90
          #0 0x00000000033106d1
          #1 0x00000000033754d7
          #2 0x0000000003375605
          #3 0x00007fa74ef1d900
          #4 0x00000000028a37d1
          #5 0x00000000028a35f7
          #6 0x000000000227194f
          #7 0x00000000028a21bd
          #8 0x00000000028a0c2c
          #9 0x00000000028a27dc
         #10 0x00000000028a5dc2
         #11 0x00000000028a66d1
         #12 0x00000000028a5800
         #13 0x00000000028a5ff8
         #14 0x00000000028a6e1c
         #15 0x00000000024f8995
         #16 0x00000000024f8201
         #17 0x00000000024f1f38
         #18 0x00000000024f1c71
         #19 0x000000000252cd65
         #20 0x000000000252cb41
         #21 0x00000000024f743a
         #22 0x00000000032ae3da
         #23 0x00000000032abf23
         #24 0x0000000003256251
         #25 0x0000000003433c98
         #26 0x00007fa74ef06e6c
         #27 0x00007fa74ef06f35 __libc_start_main + 135
         #28 0x000000000308f34e
/tmp/ifx1281730237bYOBQW/ifx3AxWPF.i90: error #5633: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for cmp.F90 (code 3)
Here is ifx 2025.0.0 able to successfully compile the program:
$ ifx --version
ifx (IFX) 2025.0.0 20241008
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
$ifx -c cmp.F90
$ ls -l cmp.o
-rw-r--r-- 1 geir compiler 45576 Nov 21 15:01 cmp.o
JFH
In my Ubuntu system that code compiled OK with ifx 2025.3.0 20251010.
