29632 Discussions
Regression: defined assignment called multiple times
WileyOne
Compiler: ifx (IFX) 2026.0.0
OS: Ubuntu 22.04.05 LTS (Jammy Jellyfish)
The most recent compiler release fixed a bug I reported a while back (many thanks compiler team). Slightly modifying that example, however, still reveals problems. In short, the defined assignment is called multiple times when it should only be called once. Here is a minimal example:
module Classes_Header
    implicit none
    type :: class1
        integer :: ii
        contains
        generic,   public  :: assignment(=) => copy
        procedure, private :: copy
    end type
    type :: class2
        character(:), allocatable :: name
        type(class1) :: myClass1
    end type
    type :: class3
        type(class2) :: myClass2
    end type
    type :: class4
        type(class3), allocatable :: myClass3
    end type
    contains
    subroutine copy(lhs,rhs)
        class(class1), intent(out) :: lhs
        class(class1), intent(in)  :: rhs
        lhs%ii = 7
        print *, 'copy was called'
    end subroutine
    function constructor() result(this)
        type(class4) :: this
        allocate(this%myClass3)
        this%myClass3%myClass2%myClass1%ii = 42
    end function
end module
program main
    use Classes_Header
    implicit none
    type(class4) :: myClass4
    myClass4 = constructor()
end program
The defined assignment should only be called once, but it runs twice:
There are 2 differences from the previous bug: a "name" component was added to "class2", and the "class3" component of "class4" is "type" rather than "class". The example also exhibits the issue when the latter is "class"; both are included below.
This is a regression because this specific example worked with a previous compiler version (2024.2.0 at least); that is, the defined assignment was only called once.
While the defined assignment being called an extra time may seem like small potatoes, it is causing nasty segfaults in my actual code. Random memory is being accessed, which really ruins your day.
Please let me know if I can provide additional clarification or examples.
WileyOne
Bumping this post so that this likely bug is not lost.
