Reinstalling v9.1
kai_larsen
Hi!
In setting up my new computer (Intel 64 bit), I decided to go with v.10.0. Unfortunately, this turned out to be a mistake as I can't afford to buy the VS version required to compile for 64 bit environments. I therefore removed v10.0 and installed v.9.1.
Upon trying to compile my code, I get "Error3The Intel Linker (rc.exe) could not be found."
Any suggestions about what may have happened here?
Thanks in advance,
-- Kai :-)
You should not need to buy anything extra to use the Intel compiler in the 64-bit environment. Please submit a report to Intel Premier Support and we'll help you out.
