Reporting a Catastrophic Error
sknobat
Hi
I was trying to compile the following code (developedbyJ F Harper, Mathematics, Victoria University, Wellington). I got the following messsage:
------ Build started: Project: Console1, Configuration: Debug|Win32 ------
Compiling with Intel Visual Fortran Compiler XE 12.1.4.325 [IA-32]...
testpure.f90
0_12459
: catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for C:\\Temp\\testpure.f90 (code 1)
Build log written to "file://C:\\Temp\\Console1\\Console1\\Debug\\BuildLog.htm"
Console1 - 1 error(s), 0 warning(s)
Code
! A Fortran 95 program that compiles and runs with some compilers, but
! others can't calculate lengths of both spf and dpf. The output should be
! "-1.000". If the line near the end that says
! real :: x = -1
! is changed to
! real(dp):: x = -1
! then the offending compilers can cope and give correct output.
!J F Harper, Mathematics, Victoria University, Wellington,NZ
module findbug
implicit none
integer,parameter:: dp=kind(1d0)
interface f
module procedure dpf,spf
end interface f
contains
pure function findf( x) result (out)! with length 50
real(dp),intent(in)::x
character(len = 50):: out
write(out,"(F0.3)") x
end function findf
pure function dpf( x) ! trimmed
character:: dpf*(len_trim(findf(x)))
dpf = trim(findf(real(x,dp)))
end function dpf
pure function spf( x) ! trimmed
real,intent(in)::x
character:: spf*(len_trim(dpf(real(x,dp))))
spf = trim(dpf(real(x,dp)))
end function spf
end module findbug
program tryf
use findbug, only: dp,f
implicit none
real :: x = -1
print *,'"'//f(x)//'"'
end program tryf
Thank you
Sam
TimP
This is definitely a bug of Intel compilers; I reproduced this with a 6 week old ifort for intel64.
The workaround is as stated by the author.
I can also reproduce this. The program looks familiar - it may have been reported before. I will check.
Yep - this is our issue DPD200175919 which has not yet been fixed. Pretty much identical program source.
mecej4
I note that the program performs recursive I/O (not to the same "unit", but once to an internal file and then to standard output).
That's allowed.
This problem was fixed in the 16.0 compiler. It was particularly difficult to solve.
