Reproducer for an ifx ICE
zjibben
I'm triggering an interesting ICE with ifx (tested 2023.2 through 2025.2). The issue is some edge case combination of using parts of a module which contain a type with a finalizer exposed through an interface block. The reproducer has only declarations, nothing executable, and can be sidestepped with some interesting changes (commented below).
This is some simplified code out of AMReX as well as some of my own code depending on it.
! ifx -c ice.f90 -o ice.o
! tested triggering ICE with ifx 2023.2 through 2025.2.
module bar_type
  implicit none
  private
  public :: bar_destroy ! removing this line sidesteps the ICE
  type, public :: bar
  contains
    final :: bar_destroy
  end type bar
  ! removing this block sidesteps the ICE
  interface bar_destroy
    module procedure bar_destroy
  end interface bar_destroy
contains
  subroutine bar_destroy(this)
    type(bar), intent(inout) :: this
  end subroutine
end module bar_type
module foo_type
  implicit none
  type :: foo
  contains
    procedure :: f
  end type
contains
  subroutine f(this, x)
    ! using the entire bar_type module (no "only") sidesteps the ICE
    use bar_type, only: bar
    class(foo), intent(in) :: this
    type(bar), intent(in) :: x
  end subroutine
end module foo_type
Thomas201Tang
Hello!
You've found an Internal Compiler Error (ICE), which is a bug in the ifx compiler itself. The crash is triggered by a problematic combination of using a type-bound finalizer along with an unnecessary, explicit interface block for that same finalizer. This redundancy confuses the compiler during the module-linking process, especially when you use the use ... only: bar clause. Your workarounds correctly resolve the issue by removing the redundant declaration, and you should report this bug to Intel.
AlHill
@Thomas201Tang   Your account looks like a spam account.
[CoPilot is a virus]
Ron_Green
Bug ID is CMPLRLLVM-70660
zjibben
JohnNichols
Honored Contributor I
Interesting it crashed on ifx on VS
and IFORT with fortcom: Fatal: There has been an internal compiler error (C0000005).
