29650 Discussions
Require intel parallel studio xe 2015
ben_afia__achraf
I have a student license for Intel parallel studio but I only found 2019 and 2020 versions.In fact, I need 2015 version ( update 3) in order to link Fortran with Abaqus 6.14.
I need you help ASAP.
Thank you.
Steve_Lionel
No, that's not available for student licenses, and you don't need a version that old. You can make Abaqus work with the current version of the compiler.
Greg_T_
Valued Contributor I
Use the forum search to look for "abaqus" and there are previous posts that describe using current versions of Abaqus with Intel Fortran for user subroutines.  I am able to run Abaqus with user subroutines using the current version of Intel Fortran.  My approach is to open the Intel Fortran command window so that the environment is initialized for Fortran, then run the Abaqus job command line in that window.
Regards, Greg T.
