Resource menu editor
gelarimer
In the (MSVisualC++ Net2003) resource menu editor, characters are shown underlined when an ampersand (&) is placed before the character. For example, &File shows Filein the resource editor.However, when the program is compiled and run the main menu contains File, but F is not underlined.
I created a win32 single doc. program from scratch to see if the problem existed in the compiled template program--it did! The resorce editor shows underlined main menu items, but when compiledand run the template program did not have undelined characters in the main menu.
Anyinfowould be appreciated.
gelarimer
Found the answer in a win32 Google user group, posted by Lee Weiner:
You must be using Windows XP. By default, XP hides the underlines until you press the Alt key. To change this behavior, go to Display PropertiesAppearance | Effects, and uncheck the item labeled "Hide undelined letters..."
Lee Weiner
lee AT leeweiner DOT org
