29653 Discussions
Results error when sorting long integer array in Linux
zhangyucas
Hi all,
Recently I'm trying to call qsort to sort a long integer array on Linux, however, the result looks like wrong. And I try to call qsort to sort the same array on Windows, finding that the result is correct. Is there something wrong when I call qsort on Linux? Any suggestions will be appreciated!
The codes call qsort on Linux are as follows:
      Module Share_Type_GPU
      Type Element_Type_GPU
         Integer          :: Row
         Integer          :: Col
         Integer(8)       :: Index
         Double Precision :: Val
      End Type
      End Module Share_Type_GPU
      Subroutine Qsort_COO_Linux_GPU
      Use Global_Variables,            ONLY: Nelem,Nevab,Mposn
      Use,Intrinsic :: Iso_C_Binding,  ONLY: C_Size_T
      Use Ifport, ONLY: Qsort_Element_Types_GPU => Qsort
      Use Share_Type_GPU
      Interface
         Subroutine Qsort(Array, Len, Isize, Comp)
            Use, Intrinsic :: Iso_C_Binding, Only: C_Size_T
            Use Share_Type_GPU
            Type(Element_Type_GPU) Array(Len)
            Integer(C_Size_T) Len, Isize
            Integer(8), External :: Comp
         End Subroutine Qsort
      End Interface
      Type(Element_Type_GPU) :: C(Nelem*Nevab*Nevab)
      Integer(8), External  :: Cmp_Function_GPU
      Integer (C_Size_T) :: Size_Of_Element, Size_Of_Array
      Integer I
      Do I=1,Nelem*Nevab*Nevab
         C(I)%Val   = COO_Value(I)
         C(I)%Row   = COO_Index(I,1)
         C(I)%Col   = COO_Index(I,2)
         C(I)%Index = COO_Index(I,2)*Mposn+COO_Index(I,1)        ! Long integer larger than integer(4), so use integer(8)
      End Do
      Size_Of_Array   = Size(C)
      Size_Of_Element = Sizeof(C(1))
      Call Qsort(C, Size_Of_Array, Size_Of_Element, Cmp_Function_GPU)
         COO_Value(I)  = C(I)%Val
         COO_Index(I,1)= C(I)%Row
         COO_Index(I,2)= C(I)%Col
      End Do
      Return
      End Subroutine
      Function Cmp_Function_GPU(C1, C2)
      Use Share_Type_GPU
      Implicit None
      Type(Element_Type_GPU), Intent(In) :: C1
      Type(Element_Type_GPU), Intent(In) :: C2
      Integer(8) :: Cmp_Function_GPU
      Cmp_Function_GPU=C1%Index-C2%Index
      End Function
Thank you very much!
Mark_Lewy
Valued Contributor I
We don't have a full compilable example here, but I suggest going back to the documentation for the ifport implementation of qsort and comparing what you have done with the example there.  One obvious thing that stands out to me is that you have declared the compare function to have a return value of integer(8), when the documentation suggests integer(2).
cryptogram
Might be onto something with the integer(2) vs. integer(8)
If the comp argument is passed by reference, the endianness of windows provide a little leeway to get it wrong.
If I pass an integer(8) value to a routine expecting integer(2) on windows, it will work as expected because the first two bytes
of an integer(8) value that would fit into an integer(2) are the same as the integer(2)
For example integer(8)  value of 1 on windows shows up in memory as  01 00 00 00 00 00 00 00
and integer(2) value of 1 shows up in memory as  01 00.  So if I pass the address of integer(8) 1 to a routine expecting integer(2), it
still works.
On unix systems the order in memory is swapped to something a bit for user friendly, such that integer(8) value of 1 is
00 00 00 00 00 00 00 01
and integer(2) value of 1 is
00 01
But then passing integer(8) by reference to a routine expecting integer(2),  the subroutine will see the first 2 bytes of the integer(8) number, and so it would see 0 instead of 1.
zhangyucas
Hi cryptogram,
Your suggestion successfully solves my problem. It finally works!
Thanks for your help!
-Yu
zhangyucas
Hi Mark,
-Yu
