Reverse Communication
holysword
Hi fellows,
I am working with an (parallel) iterative solver implementation right now, and I was told to implement reverse communication mechanism on it, to "unplug" the code from the data structures.
I checked some old codes containing this strategy and they are, in majority, FORTRAN77 codes. I have to admit that there were no better way to do that in F77, but I wonder if with current intel compiler it would be possible to use some object orientation to obtain the very same effect.
I would like to have advices from people who are already familiarized with this stragegy, and would like to know if there is a better approach with the current features of intel fortran compiler (our code is FORTRAN90/2003 nevertheless).
Thank you in advance
Holysword
mecej4
From what basis do you draw that conclusion? The idea of reverse communication applies to any procedural programming language that has functions that can be called with arguments and return to the caller. There are advantages and disadvantages associated with the reverse communication mechanism, and you can find many articles about those on the Web.
Fortran 90 and later allows data to be shared by using modules and by host association, so you have more choices. Still, reverse communication remains a contender.
The current MKL library has a few solvers that exploit the reverse communication mechanism.
holysword
Hi mecej4, thank you for answering.
I was refering to the abstraction of the data structure. As far as I know, F77 doesn't have many features allowing that.
Unfortunatelly I found only discussions related to F77 (including ARPACK package), and as I mentioned before, Iam just wondering if with F90/2003 features already implemented in intel fotran compiler we can abstract the data structure from the code without using Reverse Communication, and what would be the drawbacks of each strategy.
holysword
I have implemented a "dummy algorithm" using Reverse Communication. It doesn't do anything significative, just manipualtion of some vectors, and the matrices. I implemented two simple examples, one reverse communication interface which works with diagonal matrices and the other which works with common full matrices. Follows the code:
[fxfortran]MODULE rc_mod
 IMPLICIT NONE
 INTEGER, PARAMETER :: ST_INIT=0, ST_LOOP=1, ST_DONE=999, ST_AY_OUT=3, ST_MX_OUT=4, &
                       ST_AY_IN=-3, ST_MX_IN=-4
 CONTAINS
SUBROUTINE RC_Inner(x,y,i,max_i, status)
	!-------- PARAMETERS --------
	REAL, INTENT(INOUT), DIMENSION(:) :: x, y
	INTEGER, INTENT(INOUT) :: i, status
	INTEGER, INTENT(IN)    :: max_i
	!-------- LOCAL --------
	REAL :: alpha
	!-------- INIT --------
	IF (status.EQ.ST_INIT) THEN
		i = 1
		x = 1
		y = 0
		status = ST_LOOP
	ENDIF
!--------------------- MAIN LOOP ----------------------
	DO WHILE (i.LE.max_i)
		SELECT CASE (status)
			CASE (ST_LOOP)
				x = 2*x + y
				alpha = DOT_PRODUCT(x,x)
				alpha = SQRT(alpha)
				y = x / alpha
		! 		y = A*y
				status = ST_AY_OUT
				RETURN
			CASE (ST_AY_IN)
				x = x - y
				alpha = SQRT(alpha)
				x = x / alpha
		! 		y = M*x
				status = ST_MX_OUT
				RETURN
			CASE (ST_MX_IN)
				i = i + 1
				status = ST_LOOP
		END SELECT
	END DO
! Will reach here only after finishing the loop
	status = ST_DONE
	RETURN
END SUBROUTINE RC_Inner
END MODULE rc_mod
MODULE rc_interface
 USE rc_mod
 IMPLICIT NONE
 CONTAINS
SUBROUTINE RC_Interface_Common(A, M, max_i)
	!-------- PARAMETER --------
	REAL, INTENT(IN), DIMENSION(:,:) :: A,M
	REAL, DIMENSION(:), ALLOCATABLE :: x, y
	INTEGER :: i, size_A, status
	size_A = SIZE(A,1) ! Since its, just a test, the matrix must be square
	ALLOCATE(x(size_A))
	ALLOCATE(y(size_A))
	status=ST_INIT
	CALL RC_Inner(x,y,i,max_i, status)
	DO
			CASE (ST_DONE)
				EXIT
			CASE (ST_AY_OUT)
				y = MATMUL(A,y)
				status = ST_AY_IN
			CASE (ST_MX_OUT)
				y = MATMUL(M,x)
				status = ST_MX_IN
		END SELECT
	END DO
	WRITE(*,*) '[RC_Interface_Common]:', x
END SUBROUTINE RC_Interface_Common
SUBROUTINE RC_Interface_Diag(A, M, max_i)
	REAL, INTENT(IN), DIMENSION(:) :: A,M
	INTEGER :: i, j,size_A, status
	size_A = SIZE(A)
	ALLOCATE(x(size_A))
	ALLOCATE(y(size_A))
	status=ST_INIT
	DO
			CASE (ST_DONE)
				EXIT
			CASE (ST_AY_OUT)
				DO j=1,size_A
					y(j) = y(j)*A(j)
				END DO
				status = ST_AY_IN
			CASE (ST_MX_OUT)
				DO j=1,size_A
					y(j) = x(j)*M(j)
				END DO
				status = ST_MX_IN
		END SELECT
	END DO
	WRITE(*,*) '[RC_Interface_Diag]:', x
END SUBROUTINE RC_Interface_Diag
END MODULE rc_interface[/fxfortran]
Since its just an example I didn't put error manipulation and etc. I also had in mind only square matrices, and something would go wrong otherwise. I hope I didn't mistake anything in this piece of code.
holysword
... and then I implemented the very same algorithm, using object orientation ideas. Follows the code:
[fxfortran]MODULE oo_mtx
 IMPLICIT NONE
PUBLIC
! Declaration of the ABSTRACT CLASS
TYPE, ABSTRACT ::  mtx
	! Just some cosmetics parameters
	INTEGER :: nnz, col, row
	CONTAINS
		PROCEDURE(matvec_abstract), DEFERRED :: matvec
END TYPE mtx
INTERFACE
	SUBROUTINE matvec_abstract(self,x,y)
		IMPORT :: mtx
		CLASS(mtx),         INTENT(IN)  :: self
		REAL, DIMENSION(:), INTENT(IN)  :: x
		REAL, DIMENSION(:), INTENT(OUT) :: y
	END SUBROUTINE matvec_abstract
END INTERFACE
END MODULE oo_mtx
MODULE oo_mtx_diag
 USE oo_mtx
 IMPLICIT NONE
! Declaration of the type mtx_diag
TYPE, EXTENDS(mtx) :: mtx_diag
	REAL, DIMENSION(:),ALLOCATABLE :: A
	CONTAINS
	PROCEDURE, PASS(self) :: matvec
END TYPE mtx_diag
PUBLIC
PRIVATE :: matvec
 CONTAINS
! mtx_diag constructor
FUNCTION mtx_diag_cnstr(col, row) RESULT(self)
	INTEGER, INTENT(IN) :: col, row
	TYPE(mtx_diag) :: self
	self%col  = col
	self%row  = row
	self%nnz = min(col,row)
	ALLOCATE( self%A( self%nnz ) )
	self%A = sqrt(-1.0)
END FUNCTION mtx_diag_cnstr
! mtx_diag matvec
SUBROUTINE matvec(self,x,y)
	CLASS(mtx_diag),    INTENT(IN)  :: self
	INTEGER :: j
	DO j=1,self%nnz
		y(j) = x(j)*self%A(j)
	END DO
END MODULE oo_mtx_diag
MODULE oo_mtx_common
 USE oo_mtx
 IMPLICIT NONE
! Declaration of the type mtx_common
TYPE, EXTENDS(mtx) :: mtx_common
	REAL, DIMENSION(:,:), ALLOCATABLE :: A
	CONTAINS
END TYPE mtx_common
PUBLIC
PRIVATE :: matvec
 CONTAINS
! mtx_common constructor
FUNCTION mtx_common_cnstr(col, row, nnz) RESULT(self)
	INTEGER, INTENT(IN) :: col, row, nnz
	TYPE(mtx_common) :: self
	self%col = col
	self%row = row
	self%nnz = nnz
	ALLOCATE( self%A( row, col ) )
	self%A = sqrt(-1.0)
END FUNCTION mtx_common_cnstr
! mtx_diag matvec
	CLASS(mtx_common),  INTENT(IN)  :: self
	y = MATMUL(self%A,x)
END MODULE oo_mtx_common
MODULE oo_mod
 USE oo_mtx
 IMPLICIT NONE
 CONTAINS
! MAIN SUBROUTINE
SUBROUTINE OO_Interface(A, M, max_i)
	CLASS(mtx), INTENT(IN)  :: A, M
	REAL, DIMENSION(A%col) :: x, y
	REAL :: alpha
	INTEGER :: i
	x = 1
	y = 0
	DO i=1,max_i
		x = 2*x + y
		alpha = SQRT(alpha)
		y = x / alpha
		CALL A%matvec(y,y)
		x = x - y
		alpha = SQRT(alpha)
		x = x / alpha
		CALL M%matvec(x,y)
	END DO
	WRITE(*,*) '[OO_Interface]:', x
END SUBROUTINE OO_Interface
END MODULE oo_mod
[/fxfortran]
holysword
So, answering my initial question: is it possible to implement abstraction of data type using other strategy than Reverse Communication? The answer is "yes", as I have just shown. I wrote a code for testing this implementation, which follows now:
[fxfortran]PROGRAM main
USE rc_interface
USE oo_mtx_diag
USE oo_mtx_common
USE oo_mod
IMPLICIT NONE
REAL, DIMENSION(5,5) :: A1, M1
REAL, DIMENSION(5)   :: A2, M2
TYPE(MTX_COMMON)     :: A3, M3
TYPE(MTX_DIAG)       :: A4, M4
INTEGER :: max_i
! Standard
A1(1,:) = (/ 1.0, 0.0, 0.0, 0.0, 0.0/)
A1(2,:) = (/ 0.0,-2.3, 0.0, 0.0, 0.0/)
A1(3,:) = (/ 0.0, 0.0, 1.0, 0.0, 0.0/)
A1(4,:) = (/ 0.0, 0.0, 0.0,-1.4, 0.0/)
A1(5,:) = (/ 0.0, 0.0, 0.0, 0.0, 5.0/)
M1(1,:) = (/-1.0, 0.0, 0.0, 0.0, 0.0/)
M1(2,:) = (/ 0.0, 2.0, 0.0, 0.0, 0.0/)
M1(3,:) = (/ 0.0, 0.0, 1.2, 0.0, 0.0/)
M1(4,:) = (/ 0.0, 0.0, 0.0, 1.0, 0.0/)
M1(5,:) = (/ 0.0, 0.0, 0.0, 0.0, 2.9/)
! Diagonal
A2 = (/ 1.0,-2.3, 1.0,-1.4, 5.0/)
M2 = (/-1.0, 2.0, 1.2, 1.0, 2.9/)
! Class Standard
A3 = mtx_common_cnstr(5,5,5)
M3 = mtx_common_cnstr(5,5,5)
A3%A = A1
M3%A = M1
! Class Diagonal
A4 = mtx_diag_cnstr(5,5)
M4 = mtx_diag_cnstr(5,5)
A4%A = A2
M4%A = M2
max_i = 1
CALL RC_Interface_Common(A1, M1, max_i)
CALL RC_Interface_Diag(A2, M2, max_i)
CALL OO_Interface(A3, M4, max_i)
CALL OO_Interface(A4, M3, max_i)
END PROGRAM[/fxfortran]
Once again, its just a test. I find interesting also is that OO_Interface can receive BOTH mtx_diag and mtx_common (that is, they can be mixed), whereas for Reverse Communication I would have to create a new RC_Interface_CommonDiag for doing that (and perhaps anotherRC_Interface_DiagCommon). I would dare to say that the object orientation strategy is more general and flexible. Another important point (which is a matter of personal opinion): I find it much easier to read, write and manipulate the object oriented version.
But the most important question would still remain. What are the disvantages regarding the object oriented version? Would it have any (considerable) performance problems? The fact that matvec is a DEFERRED procedure would make it impossible to inline the function at compiling time (right?), but can the Reverse Communication version be inlined without problems? If the MATMULT instriscic function is what takes most of the computational time (let's say, 98%), would the context exchange of calling matvec function decrease significatively the performance of the whole algorithm?
