29390 Discussions
Runtime errors are anonymous unless there is a console
Andrew_Smith
Valued Contributor I
If I dont have the console open all I can see is a message saying a breakpoint has been reached. So then I have no idea what the problem actually is.
One example is the message for a variable being used without being defined.
jimdempseyatthecove
Add conditional code to your program to (conditionally) make a call to AllocConsole().
When debugging, enable the condition that allocates the console window.
Jim Dempsey
Steve_Lionel
The message is in another window that is often behind the VS window.
