Runtime ifx/ifort compiler bug
NCarlson
The following example produces what I believe is a spurious runtime error.  It runs correctly using gfortran.  The example involves defined assignment of polymorphic variables and assignment of unlimited polymorphic components.
module foo_class
  type, abstract :: foo
  contains
    procedure, private :: foo_copy
    generic :: assignment(=) => foo_copy
    procedure(foo_copy), deferred :: foo_copy_
  end type
  type, extends(foo) :: foo_bar
    class(*), allocatable :: value
  contains
    procedure :: foo_copy_ => foo_bar_copy
  end type
contains
  subroutine foo_copy(lhs, rhs)
    class(foo), intent(inout) :: lhs
    class(foo), intent(in) :: rhs
    if (same_type_as(lhs, rhs)) then
      call lhs%foo_copy_(rhs)
    else
      error stop
    end if
  end subroutine
  subroutine foo_bar_copy(lhs, rhs)
    class(foo_bar), intent(inout) :: lhs
    select type (rhs)
    type is (foo_bar)
      print *, 'before foo_bar assignment'
      lhs%value = rhs%value ! RUNTIME ERROR HERE
      print *, 'after foo_bar assignment'
    end select
  end subroutine
end module
use foo_class
class(foo), allocatable :: src, dest
!! Define SRC
allocate(foo_bar::src)
select type (src)
type is (foo_bar)
  allocate(src%value, source=1)
end select
!! Copy SRC to DEST
allocate(dest, mold=src)
print *, 'before foo assignment'
dest = src
print *, 'after foo assignment'
end
The expected results are:
With ifx I get:
$ ifx -traceback intel-20231205.f90
$ ./a.out
forrtl: severe (122): invalid attempt to assign into a pointer that is not associated
Image              PC                Routine            Line        Source
a.out              0000000000408E7F  Unknown               Unknown  Unknown
a.out              0000000000405327  foo_bar_copy               34  foo.f90
a.out              0000000000405679  _unnamed_main$$            54  foo.f90
a.out              000000000040519D  Unknown               Unknown  Unknown
libc.so.6          00007F2DA5D6A550  Unknown               Unknown  Unknown
libc.so.6          00007F2DA5D6A609  __libc_start_main     Unknown  Unknown
a.out              00000000004050B5  Unknown               Unknown  Unknown
The error message involves a pointer but there is not a pointer anywhere in this example.
Barbara_P_Intel
I agree. It's a compiler bug.
The good news is that it is fixed in the next minor release of ifx and ifort. It's planned to be released near the end of Q1 2024.
ifx -what -traceback nc.f90
 Intel(R) Fortran 24.0-1444
a.out
rm a.out
ifort -what -traceback nc.f90
ifort: remark #10448: Intel(R) Fortran Compiler Classic (ifort) is now deprecated and will be discontinued late 2024. Intel recommends that customers transition now to using the LLVM-based Intel(R) Fortran Compiler (ifx) for continued Windows* and Linux* support, new language support, new language features, and optimizations. Use '-diag-disable=10448' to disable this message.
 Intel(R) Fortran 2021.12.0-1425
a.out
NCarlson
Barbara_P_Intel
I just confirmed that the runtime error you reported is indeed fixed in ifx 2024.1.0. That version was released last week. Give it a try!
