Hello everybody. I am currently writing a SUBROUTINE in which I need two variables to be saved between callings, namely et and ey.
If I declare them this way
SUBROUTINE mysub(y)
REAL(KIND=dp), DIMENSION( : ) :: y
REAL(KIND=dp), SAVE :: et=0.0D0
REAL(KIND=dp), DIMENSION(SIZE(y,1)),SAVE :: ey=0.0D0
END SUBROUTINE mysub
the compiler complains: he doesn't like the SAVE attribute for the automatic-shaped array ey. I would like to obtain the same effect for ey, possibly without using allocatable array. I think this is a general feature in FORTRAN 90, and maybe has nothing to do with the IFORT compiler I'm using. Does anybody know how to overvcome the problem? Thank in advance.
Daniele
SUBROUTINE mysub(y)
Daniele
Make it ALLOCATABLE rather than automatic and allocate it to the desired bounds. Or consider using a module variable. You're right that this is not a compiler issue. The whole idea of automatic arrays is that their size is determined when you enter the routine. What would it mean to save that for a different call (when the bounds might be different)?
Thanks for your reply. I'll try to explain what I need to do. Concentrate on the variable et. Look at the following
SUBROUTINE mysub(y)
et = et +1.0_dp
The very first time I call mysub, the variable et is set to zero. During the procedure it is updated and the value et is saved for the next time I call the subroutine.
Now I want to reproduce exactly the same effect with an array, say ey. Here is my solution
SUBROUTINE mysub(y)
REAL(KIND=dp), DIMENSION( : ), ALLOCATABLE :: ey
et = et +1.0_dp
IF (.NOT.ALLOCATED(ey)) THEN
ALLOCATE (ey(SIZE(y,1)))
ey = 0.0_dp
ENDIF
ey = ey + 1.0_dp
This is what I have written to obtain this effect. What I don't like in this approach is that when I return back to the main program, the variable ey cannot be DEALLOCATED. That's why I was asking for something different from an allocatable array. What do you mean by considering a module variable?
Cheers
SUBROUTINE mysub(y)
et = et +1.0_dp
SUBROUTINE mysub(y)
et = et +1.0_dp
ey = 0.0_dp
ENDIF
ey = ey + 1.0_dp
Cheers
Message Edited by d.avitabile on 10-05-2005 02:21 AM
Message Edited by d.avitabile on 10-05-2005 02:23 AM
following
SUBROUTINE mysub(y)
et = et +1.0_dp
SUBROUTINE mysub(y)
et = et +1.0_dp
ey = 0.0_dp
ENDIF
ey = ey + 1.0_dp
Cheers
following
SUBROUTINE mysub(y)
et = et +1.0_dp
SUBROUTINE mysub(y)
et = et +1.0_dp
ey = 0.0_dp
ENDIF
ey = ey + 1.0_dp
Cheers
Well, your variable et isn't deallocated either, is it?
I was suggesting something like this:
module globals
use kinds ! defines dp
real(dp), dimension(:), allocatable :: ey
end module globals
You would then "use globals" to make ey visible and use the same code you showed to conditionally allocate it.
You can then deallocate ey where and when you want as long as you USE globals.
module globals
end module globals
Topic Options
