SCROLLBAR in QuickWin
martin_bauer
Hallo,
The example from newest IVF compiler in
C:\Program Files (x86)\Intel\Compiler\11.1\046\Samples\en_US\Fortran\QuickWin.zip
1. It seems to me that the inputs for Celsius & Fahrenheit are only integers. Does anyone knows how can I change them into real or double type?
2. I have change the temperature range from -273C to 200C by adding
retlog = DlgSet( dlg, IDC_SCROLLBAR_TEMPERATURE, -273, DLG_RANGEMIN)
retlog = DlgSet( dlg, IDC_SCROLLBAR_TEMPERATURE, 209, DLG_RANGEMAX)
The SCROLLBAR do not works well when mouse draws it into the region, where Celsius temperature is small than zero. It will spring to the biggest value automatic.
Could anyone give me any advice?
Lei
Kevin_D_Intel
I attached one possible approach for item 1.
Kevin_D_Intel
