29653 Discussions
SELECT TYPE and polymorphic type comps
jahern
Hello again,
Here is a chunk of code that I believe should be valid and compile, but it fails for ifort 11.1.056 with an error. The code is:
[plain]MODULE bug3
   IMPLICIT NONE
   TYPE, ABSTRACT :: Shape
      INTEGER :: index
   END TYPE Shape
   TYPE, EXTENDS(Shape) :: Triangle
      INTEGER :: points(3)
   END TYPE Triangle
   TYPE Container
      CLASS(Shape), ALLOCATABLE :: obj
   END TYPE Container
CONTAINS
FUNCTION nSides(this)
   IMPLICIT NONE
   CLASS(Container), INTENT(IN) :: this
   INTEGER :: nSides
   IF (ALLOCATED(this%obj)) THEN
      SELECT TYPE (this%obj)
      CLASS IS (Triangle)
         nSides = 3
      CLASS DEFAULT
         STOP
      END SELECT
   ELSE
      STOP
   ENDIF
END FUNCTION nSides
END MODULE bug3[/plain]
The error I receive is:
[plain]bug3.F90(21): error #8253: If selector expression in SELECT TYPE is not a named
variable, associate-name=> shall appear.
compilation aborted for bug3.F90 (code 1)[/plain]
It would seem to me that the %obj component of a TYPE(Container) object should be visible to the function as it must always be present (and the ALLOCATED statement was accepted); I assume this would make it a "named variable". In that case, this would be an error on valid code. Of course, I could always be missing something! This error may be related to my earlier posts, as changing the dummy argument CLASS(Container) to TYPE(Container) additionally generates error #8307 (twice).
Jared
I believe that the compiler is correct. The rule in the standard is worded just like the error message. this%obj is not a named variable, it is an "object designator". So, you'd need to add the associate-name here.
Kevin_D_Intel
I still error #8253 using a development compiler containing a fix for the earlier internal compiler error (here), so I need to ping Development for further advice about this error and error #8307. More when I know it.
jahern
Ah, my mistake, I didn't recognize a difference between named variables and object designators! Adding an associate-name does clear this up (minus the #8307 errors with TYPE substituted for CLASS). I didn't realize that this a was required here - must have missed C835, and reading 8.1.9.1 para 2 led me to believe it was optional. On the surface, it seems odd to require associate-name, but I suppose that if it is a TBP or other procedure, you would just want to execute it once during the SELECT TYPE... perhaps.
Thanks!
Hirchert__Kurt_W
New Contributor II
Quoting - jahern
Thanks!
Actually, the relevant difference is not that between variables and object designators, but that between simple names and general designators. In a sense, SELECT TYPE always requires an associate-name, but it allows you to syntactically omit specifying the name if there is an obvious default. If the selector expression is a simple name, then that name is that obvious default associate-name.
Why does SELECT TYPE need an associate-name? Your example is somewhat unusual in that it does nothing triangle-specific after determining that the shape is a triangle. [As such, it could have been implemented using the intrinsic function EXTENDS_TYPE_OF instead of a SELECT TYPE contruct.] A more typical example would either reference a type bound procedure specific to triangles (which we do not have in this example) or a component specific to triangles (in this case, the component points). To do this, we need a name whose static type or class is triangle. That name is the associate-name. The associate-name is effetively declared to be CLASS(triangle) in the block following the CLASS IS (triangle) statement and CLASS(shape) in the block following the CLASS DEFAULT statement.
The associate-name is the whole point of the SELECT TYPE construct. If you do not need an associated name with the appropriate properties, you can get by with EXTENDS_TYPE_OF and/or SAME_TYPE_AS.
-Kurt
