SELinux problem
subbareddy2009
When i try to install fortran 77 compiler in my pc by running ./install.sh the following message appears in the screen. i am unable to locate SELinux..
We currently support only "Permissive" mode, which is
not found on the system.
To rectify this issue, you may either disable SELinux by
- setting the line "SELINUX=disabled" in your /etc/sysconfig/selinux file
- adding "selinux=0" kernel argument in lilo.conf or grub.conf files
or make SELinux mode adjustment by
- setting the line "SELINUX=permissive" in your /etc/sysconfig/selinux file
or ask your system administrator to make SELinux mode adjustment.
You may need to reboot your system after changing the system parameters.
More information about SELinux can be found at http://www.nsa.gov/selinux/
Quitting! Press "Enter" to terminate install.
Ron_Green
Quoting - subbareddy2009
Some Linux distributions have this Security Enhanced (SE) feature enabled by default. Do as the installer says:
If that file /etc/sysconfig/selinux does not exist, create it, add the line
SELINUX=disabled
and reboot.
ron
