SETVARS usage to run older version
dajum81
Is there a way to set up a command prompt environment to run ifort when I have installed 2025?  Is a config file the way to do this via the setvars call?  I googled a lot and couldn't find the syntax to be able to do this.  What goes in the config file?  I want to run either 2021.13.1 or 2021.10, both of which are still installed.
TIA
Dave
andrew_4619
"C:\Program Files (x86)\Intel\oneAPI\2024.1\oneapi-vars.bat"
I have not tried it but each older install has the bat file above which is setvars.bat.  The actual start menu shortcuts run a setvars higher up the chain which is for the latest version as you have found. Shortcuts for older versions get removed by the installer.
Devorah_H_Intel
