29607 Discussions
SOLVED - Problem with Parallel Studio XE 2017 Update 4 Composer Ed. for Fortran
Ted_Lillys
I solved it myself - not a compiler issue - totally a user issue - imagine that
Ted
Hi all,
Installed the update over the weekend (see details below). Compiled a 32 bit console application and tried to debug in the IDE and received the following message:
I checked various path settings, looked into %INTEL_DEV_REDIST% {C:\Program Files (x86)\Common Files\Intel\Shared Libraries\} and found the same version of the dll (17.0.1.0) as in C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2017.4.210\windows\
Used depends.exe to look for the entry point and found the function in the dll.
Any thoughts as to why the error is appearing?
Ted
Microsoft Visual Studio Community 2015
Version 14.0.25431.01 Update 3
Microsoft .NET Framework
Version 4.6.01055
Intel® Parallel Studio XE 2017 Update 4 Composer Edition for Fortran Windows*   Package ID: w_comp_lib_2017.4.210
Intel® Parallel Studio XE 2017 Update 4 Composer Edition for Fortran Windows* Integration for Microsoft Visual Studio* 2015, Version 17.0.0047.14,
Kevin_D_Intel
Glad you resolved it. What was your finding?
Ted_Lillys
Unfortunately I don't have a precise cause, but I believe it had something to do with the way I declared or attempted to allocate an allocatable array.
