29650 Discussions
[SOLVED] ifort compiler source problems
ljbutler
Hey guys, new here, but I've installed the compiler before, but not on Ubuntu 10.10. So I got it installed and have been trying to compile, however, I have to type
source /opt/intel/bin/ifortvars.sh ia32
every time I open a new terminal. I've tried placing that same line at the end of my ~/.bashrc file with no luck. Like I said, I've installed this before on 10.04 and 9.10 with little to no problems.
Thank you in advance for any help you can give me.
Logan
Ron_Green
Interesting, have you tried placing this at the top of your .bashrc? You can also add it to /etc/profile or /etc/bash.bashrc as a test, but again, put it near the top. this is because some conditionals may early exit the scripts.
You are using bash shell, right? echo $0 will return your shell
ron
ljbutler
Yeah, I am using bash and I believe I fixed it. I just had to put the source line after the first command in the .bashrc file and it was good to go. It loads that file every time I've tested closing and opening and new terminal. So we'll see if it holds through a restart. If not, I'll be back, but I expect it to work. Thanks a ton, Ron!
Logan
