SegFault with REAL128 conversion
holysword
The following code
PROGRAM test_stuff
  USE, INTRINSIC :: ISO_FORTRAN_ENV
  IMPLICIT NONE
  INTEGER(KIND=INT8) :: ivar1
  REAL(KIND=REAL128) :: rvar1
  PRINT *,"real128: ", real128
  ivar1 = 9
  rvar1 = cnv_real128(ivar1)
  CONTAINS
  FUNCTION cnv_real128(icls) RESULT(out)
    CLASS(*), INTENT(IN)  :: icls
    REAL(KIND=REAL128), ALLOCATABLE :: out
    ALLOCATE(out)
    SELECT TYPE(icls)
        TYPE IS (INTEGER(KIND=INT8))
        out = REAL(icls, KIND=REAL128)
      CLASS DEFAULT
        out = REAL(0.0,KIND=REAL128)
    END SELECT
  END FUNCTION cnv_real128
END PROGRAM test_stuff
gives me a segmentation fault at runtime. Replacing REAL128 with REAL64 gives me no error. I've tried with ifort-16.0 and 17.0. Is this somehow expected?
Thanks in advance!
jimdempseyatthecove
Try attributing out with 16 byte alignment.
 !DIR$ ATTRIBUTES ALIGN: 16 :: out
Jim Dempsey
The problem is caused by the function result being ALLOCATABLE and REAL128 - something is going very wrong there and I'll create a bug report for it. If OUT is not ALLOCATABLE, it works fine. Issue ID is DPD200415360.
