Segfault with final method
pwl_b
Hi, I have detected, what I believe, is a bug in ifort (13.0.0 20120731). The following code produces a segfault for no reason known to me.
module mod_b
  type :: b
   contains
     final :: finalize
  end type b
contains
  subroutine finalize(self)
    type(b) :: self
  end subroutine finalize
end module mod_b
module mod_t
  use mod_b
  type :: tt
   contains
     procedure :: get
  end type tt
contains
  subroutine get( self, box)
    class(tt), target :: self
    type(b), pointer, intent(out), optional :: box
    if( present(box) ) nullify(box)
  end subroutine get
end module mod_t
program d1
  use mod_t
  type(tt) :: t
  call t%get()
end program d1
When any of the options "pointer, intent(out), optional" are altered or removed the segfault disappears.
Paweł Biernat.
Anonymous66
Valued Contributor I
Hello Pawel, Thank you for reporting this problem. I have escalated this issue to the developers. The issue number is DPD200236504. I will post any updates I receive to this thread. Regards, Annalee Intel Developer Support
Anonymous66
Anonymous66
Hello Pawel, A fix has been found for this issue. We are planning to include it in an update which is currently planned for mid-January. Regards, Annalee
Anonymous66
Hello Pawel,
This is issue has been fixed in Intel® Fortran Composer XE for Linux* 2013 Update 3 which is now available at the Intel® Registration Center.
Annalee
