29647 Discussions
Segmentation Error when switching from linux to mac
kamyar_d_
I could compile and run a code on linux clusters without a problem. Now I want to run the same code on a brand new iMac, but I receive segmentation error when I run the same code. On linux I had to use the following flag:
FC=ifort
FFLAGS= -mcmodel medium -shared-intel
but because -mcmodel is not supported, I have to comment it out. Can this be the reason of this problem?Is there any alternative for MACs?
I have tried the following flags and non of them works:
FFLAGS= -heap-arrays
or
FFLAGS= -heap-arrays 10
or
FFLAGS= -Wl,-stack_size -Wl,10000000
PS: I just bought the iMac and I've installed the last version of intel fortran parallel studio.
TimP
Recall that heap-arrays is best used without a numeric argument.
Doesn't Mac support environment variables for stack limit?
If trying to eliminate mcmodel on account of large arrays, you would consider allocatable.
