29594 Discussions
Segmentation Fault (Core Dumped) when Using Intel Sequential MKL DGEMM Inside OpenMP Parallel Loop
AkhilAkkapelli
I'm trying to perform matrix multiplication using Intel Fortran Compiler (ifort) with OpenMP and MKL's DGEMM routine. The code divides matrices into blocks and uses OpenMP for parallel execution. However, I encounter a "Segmentation fault (core dumped)" error when running the program.
compilation command:  ifort -qopenmp -qmkl=sequential matmul.f90
Here’s a simplified version of my code:
integer, parameter :: n = 9 ! Number of rows and columns of matrix
integer, parameter :: nt = 3 ! Sq root of number of threads
real(8), dimension(n,n) :: A, B, C
integer :: nb ! Block size
integer :: bi(nt,2) ! Start and End indices of block matrices
integer :: i, j, k
integer :: starttime, endtime, countrate
call omp_set_num_threads(nt*nt)
print*, "Number of OMP Threads", nt*nt
call random_number(A)
call random_number(B)
if (mod(n,nt) == 0) then
    nb = n/nt
else
    nb = n/nt + 1
end if
!print*, "block size", nb
do i = 1, nt
    bi(i,1) = 1 + nb*(i-1)
    bi(i,2) = min(nb*i,n)
end do
call system_clock(starttime, countrate)
!$OMP PARALLEL DO COLLAPSE(2)
do i  = 1, nt
    do j = 1, nt
        call DGEMM('N', 'N', n, n, n, 1.0d0, A(bi(i,1):bi(i,2), :), n, &
                   B(:, bi(j,1):bi(j,2)), n, 0.0d0, &
                   C(bi(i,1):bi(i,2), bi(j,1):bi(j,2)), n)
    end do
end do
!$OMP END PARALLEL DO
call system_clock(endtime)
Labels (2)
