29578 Discussions
Serial Number for Intel Visual Fortran Compiler 15.0.7.287 License
Ruqhaiya
We need to install the Intel Visual Fortran Compiler 15.0.7.287 which needs to be used with PSCAD v4.6.3. For the same we need Serial Number of the Intel® oneAPI Base and HPC Toolkit (Single-Node). license which we have acquired.
 We have already installed Intel Fortran Compiler Classic 2021.11.0. The License has been registered in the name of MD Ruqhaiya (Email Id - ruqhaiya.m@lntecc.com).
Where can we get the Serial Number for Intel Visual Fortran Compiler 15.0.7.287 so that we can enter the same during installation?
Steve_Lionel
You don't need that ancient compiler. While purchased support of a oneAPI compiler does give you access to some older versions, not to one ten years old.
At most you may need to edit whatever scripts PSCAD uses to locate the Fortran compiler.
