29653 Discussions
Set Intel Fortran 64bit environment variable
MaylandFaizal
hello, I have a problem when I want to install ASPEN, the problem is as shown below, is there a solution for me to solve this?
IanH
That's a better question for AspenTech.
jimdempseyatthecove
Try:
Start | Intel oneAPI 2023 | ... command prompt for Intel 64 ...
IOW launch the command line window with the environment variables (Intel 64 in this case).
Then issue the command line to run the ASPEN installler program from within that CMD window.
Cannot say that that will work, but worth a try until ASPEN support is available.
Jim Dempsey
JohnNichols
Honored Contributor I
I would try the three steps outlined in the picture.  Worth a shot.
