SetEnv?
rrobinson2
I have Windows 7(64)and .Net frameowrk 4, VF 11.1.051
I know that VF 11 doesn't support Visual Stusio 10 but I should be able to use
a command-line-interface?
During custom installation I specify the MicroSoft Windows SDK, and 32/64 versions.
When I open a Fortran command-line-interface I get a message saying that
"SetEnv" is not recognized, and subsequent compiles then fail (same for 32 or 64).
What am I missing?
mecej4
Assuming that one should be able to use a CLI to VF11, the following suggestions won't need much effort to try.
Can you open a Windows SDK command window through Start->Programs->... ? The "missing" file SetEnv.Cmd is in the Bin subdirectory of the SDK installation, e.g., C:\Program Files\Microsoft SDKs\Windows\v7.0\Bin\SetEnv.Cmd.
This file is CALLed from the Visual Fortran startup batch file, ifortvars_.bat. Check if the correct path to the SDK is used in this batch file and correct if not so.
Likewise, see if the correct path to Link.exe is entered in the file ifort.cfg in the bin/ subdirectory of the VF11 installation.
You will need to manually edit ifortvars.bat to establish the VS environment. No promises that it will work.
