29641 Discussions
Setting character string variables in idb
ereisch
New Contributor II
There should be an option to efficiently set character string variables in idb. Currently, the only way I'm aware of to set a multi-character variable string is to do a series of "set VAR(1) = 'T'; set VAR(2) = 'E'; set VAR(3) = 'S'; set VAR(4) = 'T'".
There should be an ability to set a series of consecutive characters in bulk, just as you can in code. i.e. "set VAR(1:4) = 'TEST'", or better yet, "set VAR = 'TEST'" or "set VAR(1) = 'TEST'".
TIA
Kevin_D_Intel
Thank you for the post. Unfortunately this is a known limitation with IDB that Development may address in a future release. I associated the post with the the existing internal tracking id (see below) so as to keep it updated with any new developments.
(Internal tracking id: DPD200223507)
(Resolution Update on 8/30/2014): The internal tracking id has been closed as “Will not fix” to coincide with depreciation and removal of the Intel Debugger (IDB) from the Intel® Parallel Studio XE 2015 Release (refer to Intel® Parallel Studio XE 2015 Composer Edition for Linux* Release notes for some information)
Kevin_D_Intel
