Shared Object from CPP
anuraag
I have been trying to develop a shared object in Fortran and then invoke it from a CPP program.
I started with a simple Hello world example. The fortran code (foo.f90) was:
SUBROUTINE foo(ctr)
IMPLICIT NONE
INTEGER, INTENT(IN)::ctr
INTEGER :: index
do index = 1,ctr
write (*,*) "Hello World"
end do
END SUBROUTINE FOO
This was then compiled using the
ifc -fPIC -shared -o foo.so foo.f90
The excerpts from the cpp file (firstdl.cpp) which invoked the DSO are
void* handle;
typedef void (*foo_t)(int);
char* error;
int i;
i=3;
foo_t printer;
handle = dlopen ("/home/mohan/code/fortran/foo/foo.so", RTLD_LAZY);
printer = (foo_t) dlsym (handle, "foo_");
/* Call the function. */
printer(i) ;
dlclose(handle);
Note that dlsym is passed foo_, because of the name decoration done by IFC. This was found out using
nm foo.so | grep goo
The cpp code was compiled using the command
gcc firstdl.cpp -ldl
When a.out was executed, I got the error message
Segmentation fault (core dumped)
The same code worked whe I was not passing any parameters from CPP to Fortran. ie the signature of foo was
void foo(void).
I really dont know what the problem might be. Also I am a newbie to Linux and this is the first code I am running using gcc/ifc.
Anuraag Mohan
[email protected]
Martyn_C_Intel
By default, Fortran expects function parameters to be passed by reference, so you need void foo(∫)
(There are ways to get Fortran functions to accept arguments passed by value, but there's no need to complicate your life). See the section on mixed language programming in the Fortran User's Guide.
Martyn
