29636 Discussions
Sharing Fortran Memory with .NET C# (or Java)
tsmithapp-geo-resear
Does anyone have experience with or can reference some sample code or documenton how to
share a Fortran memory spacefrom withina .NET C#program.Basically we have some large
arrays that we would rather not pass from one to the other but simply populate withFortran
and use inC# (or Java)
onkelhotte
New Contributor II
I have never tested to exchange pointer adresses between C# and Fortran (thats what you intend to do, right?).
But if you even succeed in doing so, you have to keep in mind that Fortran and C# are saving arrays differently (one in column order, the other in row order...).
Markus
Quoting - onkelhotte
Markus
I was thinking more along the lines of shared memory. Two executables sharing a block of memory where the Fortran writes to the memory area and C# reads it.
TimP
If you declare an array via iso_c_binding, it will appear the same as an array declared in unmanaged C code.
My understanding is that C# runs only in the .NET environment so that it does not share memory with unmanaged code. You should use access routines in a DLL to share data.
