Sharing resources
moncef
I used CVF to built an MDI project and I associated to it a Dll as subproject. Inside the DllI define a simple dialog ( resources , call back routines ) and a subroutine DisplayDialog wich create the dialog with the CreateDialogParam and show it with ShowWindow.
When I call the subroutine DisplayDialog from the MDI project , the dialog isn't displayed. But when I insert the same dialog like a new resource in the MDI ( I use the same name used in the Dll) and I call the subroutine DisplayDialog it works.
How to do to force the MDI to use resources defined in the Dll?
Thanks for your help in advance
anthonyrichards
New Contributor III
If the dialog resource is in a DLL, you need to use DLGINITWITHRESOURCEHANDLE to initialise your dialog. e.g.
hmodule=GetModuleHandle ('MYRESOURCE.DLL')
iret=DLGINITWITHRESOURCEHANDLE (ID_DIALOG, hmodule, dlg)
Look it up in the help.
moncef
Quoting - anthonyrichards
i insert the instruction :iret=DLGINITWITHRESOURCEHANDLE (ID_DIALOG, hmodule, dlg) in the main propgram but the problem persists.The dll code called BurnersClass is :
MODULE MDI_DIALOG
use Common_DerivedTypes
use DFWIN
integer, private:: iret
integer, private:: dllDialog_handle
Contains
!______________________________________________________________!
subroutine ComponentMenu(ghInstance,hwnd)
!DEC$ ATTRIBUTES STDCALL,ALIAS :"ComponentMenu":: ComponentMenu
!DEC$ ATTRIBUTES DLLEXPORT::ComponentMenu
use dflogm
implicit none
include "resource.fd"
integer ghInstance
integer hwnd
integer dialogH
integer id
dialogH=CreateDialogParam(ghInstance,IDD_DIALOG_dll,hwnd,loc(DialgCallBack),0)
iret=ShowWindow(dialogH,SW_SHOW)
return
end subroutine ComponentMenu
integer*4 function DialgCallBack( hDlg,message,uParam,lParam )
!_-_-_-_-_-_-_-_- Compiler options _-_-_-_-_-_-_-_-!
!DEC$ ATTRIBUTES STDCALL,ALIAS :"DialgCallBack":: DialgCallBack
!_-_-_-_-_-_-_-_- USED MODULE _-_-_-_-_-_-_-_-!
use comctl32
use DFWIN
use user32
use kernel32
Implicit None
include 'RESOURCE.fd'
!_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_- USED VARIABLES _-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-!
integer hDlg
integer message
integer uparam
integer lparam
logical free_status
select case(message)
case( WM_INITDIALOG)
DialgCallBack=1
return
case (WM_COMMAND)
select case (LOWORD(uParam))
case(IDOK)
iret=1
end select
DialgCallBack=1
return
case(WM_close)
iret= destroyWindow(hDlg)
return
end select
DialgCallBack=0
return
end function DialgCallBack
END MODULE MDI_DIALOG
the part of the main program :
! FUNCTION: MainWndProc ( hWnd, mesg, wParam, lParam )
! PURPOSE: Processes messages for the main window
! COMMENTS:
integer function MainWndProc ( hWnd, mesg, wParam, lParam )
!DEC$ IF DEFINED(_X86_)
!DEC$ ATTRIBUTES STDCALL, ALIAS : '_MainWndProc@16' :: MainWndProc
!DEC$ ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS : 'MainWndProc' :: MainWndProc
!DEC$ ENDIF
use user32
use kernel32
use dfwbase
use ThessGlobals
use dflogm
implicit none
integer*4 hWnd
integer*4 mesg
integer*4 wParam
integer*4 lParam
include 'resource.fd'
! Variables
type (T_CLIENTCREATESTRUCT) clientcreate
type (T_MDICREATESTRUCT) mdicreate
type (Dialog) dlg
type (PERWNDINFO) Info
pointer (P_ComponentMenu,ComponentMenu)
integer hwndChildWindow
integer hInfo
integer pInfo
integer IDD_DIALOG_dll
integer hActiveChild
integer dllDialog_handle
integer ret
character(SIZEOFAPPNAME) lpszTitle, lpszCaption
character(SIZEOFAPPNAME) lpszName, lpszHelpFileName, lpszContents, lpszMessage
character(SIZEOFAPPNAME) lpszHeader
logical Lret
logical free_status
interface
integer*4 function AboutDlgProc( hwnd, mesg, wParam, lParam )
!DEC$ ATTRIBUTES STDCALL, ALIAS : '_AboutDlgProc@16' :: AboutDlgProc
!DEC$ ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS : 'AboutDlgProc' :: AboutDlgProc
!DEC$ ENDIF
integer*4 hwnd
integer*4 mesg
integer*4 wParam
integer*4 lParam
end function
end interface
interface
!DEC$ ATTRIBUTES DLLIMPORT::ComponentMenu
implicit none
integer ghInstance
integer hwnd
end interface
select case ( mesg )
! WM_CREATE: Create the MDICLIENT window which contains the MDI children
case (WM_CREATE)
lpszName = "MDICLIENT"C
clientcreate%hWindowMenu = ghMenuWindow
clientcreate%idFirstChild = 1
ghwndClient = CreateWindow( &
lpszName, ""C, &
IOR(WS_CHILD, IOR(WS_CLIPCHILDREN, WS_VISIBLE)),&
0, 0, 0, 0, &
hwnd, NULL, ghInstance, &
LOC(clientcreate))
MainWndProc = 0
return
! WM_DESTROY: PostQuitMessage() is called
case (WM_DESTROY)
call PostQuitMessage( 0 )
MainWndProc = 0
return
! WM_COMMAND: user command
case (WM_COMMAND)
select case ( IAND(wParam, 16#ffff ) )
case(IDM_RunDialog)
dllDialog_handle = LoadLibrary ("BurnersClass.dll"C)
if (dllDialog_handle == NULL) then
! Failure
stop
end if
P_ComponentMenu =GetProcAddress (dllDialog_handle, "ComponentMenu"C)
if (P_ComponentMenu == NULL) then
! Failure
stop
end if
ret = DlgInitwithresourcehandle(IDD_DIALOG_dll, dllDialog_handle, dlg)
call ComponentMenu(ghInstance,hwnd)
! Handle standard MDI messages
case (IDM_TILE)
ret = SendMessage( &
ghwndClient, WM_MDITILE, 0, 0)
MainWndProc = 0
return
case (IDM_CASCADE)
ghwndClient, WM_MDICASCADE, 0, 0)
MainWndProc = 0
return
case (IDM_ARRANGE)
ghwndClient, WM_MDIICONARRANGE, 0, 0)
MainWndProc = 0
return
case (IDM_NEW)
! Creates MDI child
! Allocate memory for INFO to be associated with the
! new child
hInfo = LocalAlloc(LHND, SIZEOFINFO)
if (hInfo .NE. 0) then
pInfo = LocalLock(hInfo)
if (pInfo == NULL) then
ret = MessageBox(ghwndMain,"Failed in LocalLock"C,"Error"C, MB_OK)
end if
ret = lstrcpy(lpszCaption, "MDI "C)
write (lpszCaption, 100 ) giMDICount
100 format ('MDI', I4)
Info%CaptionBarText = lpszCaption
Info%hParent = ghwndClient
call CopyMemory(pInfo, LOC(Info), 44) ! SIZEOFINFO = 44
lpszTitle = Info%CaptionBarText // ""C
lpszName ="Thess"C
mdicreate%szClass = LOC(lpszName)
mdicreate%szTitle = LOC(lpszTitle)
mdicreate%hOwner = ghModule
mdicreate%x = CW_USEDEFAULT
mdicreate%y = CW_USEDEFAULT
mdicreate%cx = CW_USEDEFAULT
mdicreate%cy = CW_USEDEFAULT
mdicreate%style = 0
! Pass the handle of the per MDI child INFO to the
! child MDI window for storage
mdicreate%lParam = hInfo
! Create Child Window
hwndChildWindow = SendMessage(ghwndClient, &
WM_MDICREATE, INT4(0), &
LOC(mdicreate))
if (hwndChildWindow == NULL) then
ret = MessageBox(ghwndMain,"Failed in Creating Child Window"C,&
"Error"C, MB_OK)
MainWndProc = 0
return
end if
giMDICount = giMDICount + 1
lret = LocalUnlock(hInfo)
else
ret = MessageBox(ghwndMain,"Failed to Allocate INFO data!"C,&
"Error"C, MB_OK)
end if
MainWndProc = 0
return
! Pass these WM_COMMAND messages to the appropriate active child
! window proc for processing
case (IDM_OPT_1, IDM_OPT_2, IDM_OPT_3, IDM_OPT_4, &
IDM_OPT_5, IDM_OPT_6, IDM_OPT_7, IDM_OPT_8)
hActiveChild = SendMessage(ghwndClient, &
WM_MDIGETACTIVE, 0, 0)
if (hActiveChild .NE. 0) then
ret = SendMessage(hActiveChild, WM_COMMAND, &
wParam, lParam)
end if
MainWndProc = 0
return
case (IDM_EXIT)
ret = SendMessage( hWnd, WM_CLOSE, 0, 0 )
MainWndProc = 0
return
case (IDM_ABOUT)
lpszName = "AboutDlg"C
ret = DialogBoxParam(ghInstance,LOC(lpszName),hWnd,&
LOC(AboutDlgProc), 0)
MainWndProc = 0
return
case (IDM_HELPCONTENTS)
lpszHelpFileName ="\Thess.hlp"C
lpszContents = "CONTENTS"C
if (WinHelp (hWnd, lpszHelpFileName, HELP_KEY, &
LOC(lpszContents)) .EQV. .FALSE.) then
lpszMessage = "Unable to activate help"C
lpszHeader = "Thess"
ret = MessageBox (hWnd, &
lpszMessage, &
lpszHeader, &
IOR(MB_SYSTEMMODAL, &
IOR(MB_OK, MB_ICONHAND)))
end if
MainWndProc = 0
return
case (IDM_HELPSEARCH)
if (WinHelp(hWnd, "Thess.hlp"C, &
HELP_PARTIALKEY, LOC(""C)) .EQV. .FALSE.) then
lpszHeader = "Thess"C
lpszMessage, &
lpszHeader, &
IOR(MB_SYSTEMMODAL , &
end if
MainWndProc = 0
return
case (IDM_HELPHELP)
if (WinHelp(hWnd, ""C, HELP_HELPONHELP, 0).EQV. .FALSE.)&
then
ret = MessageBox (GetFocus(), &
lpszMessage, &
lpszHeader, &
IOR(MB_SYSTEMMODAL,IOR(MB_OK, MB_ICONHAND)))
end if
MainWndProc = 0
return
! All of the other possible menu options are currently disabled
case DEFAULT
MainWndProc = DefFrameProc( hWnd, ghwndClient, mesg, wParam, lParam )
return
end select
! Let the default window proc handle all other messages
case default
end select
end
moncef, large files would be better attached, or even using the "code view" insert tool. See the link in my signature below for details.
moncef
thank you for the council. I rewtrite my reply :
I insert the instruction :iret=DLGINITWITHRESOURCEHANDLE (ID_DIALOG, hmodule, dlg) in the main propgram but the problem persists.The dll code called BurnersClass is :
[cpp]MODULE   MDI_DIALOG
use DFWIN
Contains
     use  dflogm
     implicit none
     integer ghInstance
     integer hwnd
     integer dialogH
     integer id
 return
         use comctl32
         use DFWIN
         use user32
         use kernel32
         Implicit None
         integer hDlg
         integer message
         integer uparam
         integer lparam
         logical free_status
                     DialgCallBack=1
                    return
         case (WM_COMMAND)
                     case(IDOK)
                     iret=1
                 end select
                 DialgCallBack=1
                 return
           case(WM_close)
                return
     end select
     DialgCallBack=0
     return
!  COMMENTS:
!DEC$ ELSE
!DEC$ ENDIF
    use user32
    use kernel32
    use dfwbase
    use ThessGlobals
    use dflogm
    implicit none
    integer*4 hWnd
    integer*4 mesg
    integer*4 wParam
    integer*4 lParam
    ! Variables
    type (Dialog)    dlg
    integer hInfo
    integer pInfo
    integer           ret
    logical Lret
    logical free_status
    interface
          !DEC$ ELSE
          !DEC$ ENDIF
          integer*4 hwnd
          integer*4 mesg
          integer*4 wParam
          integer*4 lParam
        end function
    end interface
    interface
              implicit none
              integer ghInstance
              integer hwnd
    end interface
      case (WM_CREATE)
                                    lpszName, ""C,                  &
                                    0, 0, 0, 0,                     &
                                    LOC(clientcreate))
          MainWndProc = 0
          return
      case (WM_DESTROY)
          MainWndProc = 0
          return
      case (WM_COMMAND)
              case(IDM_RunDialog)
                            ! Failure
                             stop
                       end if
                          ! Failure
                          stop
                      end if
            case (IDM_TILE)
                    MainWndProc = 0
                    return
            case (IDM_CASCADE)
                    MainWndProc = 0
                return
            case (IDM_ARRANGE)
                MainWndProc = 0
                return
            case (IDM_NEW)
            ! Creates MDI child
            !  new child
                    end if
                    lpszName ="Thess"C
                    mdicreate%style   = 0
                             LOC(mdicreate))
                                         "Error"C, MB_OK)
                        MainWndProc = 0
                        return
                    end if
                else
                            "Error"C, MB_OK)
                end if
                MainWndProc = 0
                return
                                    wParam, lParam)
                end if
                MainWndProc = 0
                return
            case (IDM_EXIT)
                MainWndProc = 0
                return
            case (IDM_ABOUT)
                MainWndProc = 0
                return
                lpszHelpFileName ="Thess.hlp"C
                                 lpszMessage,                       &
                                 lpszHeader,                        &
                end if
                MainWndProc = 0
                return
                                 lpszMessage,                       &
                                 lpszHeader,                        &
                end if
                MainWndProc = 0
                return
            case (IDM_HELPHELP)
                                                       then
                                 lpszMessage,                       &
                                 lpszHeader,                        &
                end if
                MainWndProc = 0
                return
            case DEFAULT
                return
        end select
      case default
    end select
end
[/cpp]
anthonyrichards
New Contributor III
There is no point posting reams of code without pointing out the error message, if any, and the exact point where
the program fails to perform as expected, along with the return value of a call to a function if that call fails to produce the required result.
Have you made sure that the resource-holding DLL is in the same folder as the executable that requires it, or is at least in a folder in the your search PATH?
moncef
As I had mentioned at the beginning of the discussion that when I call the subroutine ComponentMenu(ghInstance,hwnd) from the MDI project , the dialog isn't displayed. I inserted the line code : ret = DlgInitwithresourcehandle(IDD_DIALOG_dll, dllDialog_handle, dlg) as you advised it. In spite of that, the problem persists.
I join the total project in a zip file
anthonyrichards
New Contributor III
Quoting - moncef
If the resource exists in the DLL, and if the DLL is found, then dllDialog_handle will be a valid handle and the resource IDD_DIALOG_dll will be found. Check that the dialog resource exists in the DLL with exactly the name you post. Also Check that you have a valid dllDialog_handle.
edit: I have just realised that you seem to have omitteda command to display the dialog, either using DLGMODAL or DLGMODELESS. Is that correct? Add DLGMODAL(dlg) and you should see your dialog.
moncef
Quoting - moncef
When i debug the main program the return value of the instruction ret = DlgInitwithresourcehandle(IDD_DIALOG_dll, dllDialog_handle, dlg) is null in spite that the dllDialog_handle is valid (different from zero). Consequently and without dubt the error is due to the fact that the main program have'nt detected the DLL Resources.
You can see in the zip attached file, that:
1- Dll's resources are well defined.
2- In the Dll, I use the function ShowWindow to display the Dialog
With regard to DLGMODAL or DLGMODELESS, I think that oneuses them in a quickwin project not a MDI project. In the last case they generate unkown error.
Jugoslav_Dujic
Valued Contributor II
Quoting - moncef
You can use DlgModal or DlgModeless in any type of project, including even Console project (well, DlgModeless has some issues, but in principle it could work). If you use DlgModal or DlgModeless, you must use DlgInitWithResourceHandle.
What you cannot do, and you're actually doing, is to use DlgInitWithResourceHandle but to display it with DialogBox or CreateDialog[Param]. If you use DialogBox or CreateDialog[Param], you must use its hInstance argument to tell it to load from the dll.
P.S. Not really related, but you should avoid LocalAlloc/LocalLock/LocalUnlock. In the case at hand, you need just to locally declare a variable of TYPE(T_INFO) and set mdicreate%lParam to LOC(Info).
moncef
Quoting - Jugoslav Dujic
Ideed, my error isto us DlgInitWithResourceHandle to display it with CreateDialog[Param]. I took your advice and it works. Thank you very much for your help.
Concerning The P.S , did T_info is a predifinedtype?. If it is the case, in which module can i find it. I soughtin the folder c:programesFilesvisualstudioDF98include repertory without results.
a predifined type type?. If it is the case, in which module can i find it. I I sought in thing in the folder c:programesFilesvisualstudioDF98include repertory without results.
