Show Progress
brunocalado
I'm trying to show the progress of my program. It looks like:
0.0/100 %
1.0/100 %
2.0/100 %
3.0/100 %
4.0/100 %
99.0/100 %
100.0/100 %
My problem is: I don't know a nice way to return the cursor back and rewrite the last line. I want to know if is there a way to return to last printed line, clear it and rewrite again.
I know how to do it using system("clear"). But it erases other messages...
Thank you
As Ron says, there is no standard way to do it. But you can do some tricks with extensions. For example:
[plain]open (unit=6,carriagecontrol='fortran')
do i=1,10
write (6,'($,A,A,i2)') '+',char(13),i
end do[/plain]
Ron_Green
Quoting - brunocalado
0.0/100 %
1.0/100 %
2.0/100 %
3.0/100 %
4.0/100 %
99.0/100 %
100.0/100 %
Thank you
There is no standard Fortran method for doing what you want to do - to update a terminal output on the same line.
In the old days, we had control codes for VT100/VT220 terminals that would allow such a thing - but this was not standard Fortran. Rather, you send the control codes/sequences that were unique to those terminals to explicitly control the output location. I don't know of a way to do that for terminal windows - and then terminal windows are not consistent across different OSes.
ron
do i=1,10
end do[/plain]
brunocalado
do i=1,10
end do[/plain]
Thank you. You're the best!
