Sleep Routine
reneeculver
I need a Sleep function.
It should have one Argument which is the number of seconds to sleep for. Any maximum in seconds is not important as long as the maximum is greater is greater than 60 seconds.
It shoulld be simple...
I wish I had some documentation. Can anyone recommend a good reference book?
Renee
Paul_Curtis
Valued Contributor I
This would be for Win32 systems only (not portable).
[bash]RECURSIVE SUBROUTINE delay_ms (howmany)
	USE kernel32, ONLY: sleep
	IMPLICIT NONE
	INTEGER,INTENT(IN)	:: howmany
	!	Win32 suspend function, allows the timeslice to be
	!	used by other threads until the timeout elapses
	IF (howmany > 0) CALL sleep (howmany)
END SUBROUTINE delay_ms
[/bash]
psantos
Perhaps you should consider SLEEPQQ declared in IFPORT. Citing the Composer XE documentation (which by the way a recommend to you):
SLEEPQQ
Portability Subroutine: Delays execution of the program for a specified duration.
Module
USE IFPORT
Syntax
CALL SLEEPQQ (duration)
duration
(Input) INTEGER(4). Number of milliseconds the program is to sleep (delay program execution).
Example:
[fortran] USE IFPORT
 INTEGER(4) delay
 delay    = 2000
 CALL SLEEPQQ(delay)
[/fortran]
Pedro
reneeculver
Paul,Is that in C?
It doesn't compile.
Pedro, I"ll try yours.
Renee
Paul_Curtis
My routine compiles just fine, has worked for at least 10 years now. Note that this forum's stupid editor software has interpreted the greater-than symbol as html. USEing the Win32 API module Kernal32 is much more secure than IFPORT; obviously both are invoking the same API function -- how many layers of screen door do you want to kiss through?
"much more secure"? Using a Win32 API call certainly is less portable (Intel Fortran supports SLEEPQQ on all three operating systems.)
reneeculver
Pedro got it.
Sleep is synchronous and perfect here.
Renee
reneeculver
"(Intel Fortran supports SLEEPQQ on all three operating systems.)"
I'm afraid that under NO circumstances do I write code for any of the Unix series.
Renee
Renee,
You had LIB$SLEEP - which I wrote. It used $HIBER and $SCHDWK (without the latter you'd never wake up.)
reneeculver
Steve,
I didn't know - Do you have a recommendation for a book I can read?
Where do I find the Lib$ routines? Help is still useless with VS and so this messes up Intel help.
Renee
Were you really a VMS developer and you don't remember the LIB$ routines? Those were VMS Run-Time Library routines. I was a developer for the VMS OS from 1978-1988 and wrote the LIB$SLEEP routine in 1979. As has been said in this thread, use SLEEPQQ.
If you are having trouble with the help, please explain. I don't know what you mean by "messes up Intel help". You could have typed "sleep" into the Index tab and found the entry. There is also a handy table, though well buried in the documentation. Language Reference > A to Z Reference > Language Summary Tables. This lists groups of library routines by type.
reneeculver
Yes I was a VMS developer and DO remember the Lib$ routines BUT I can't find them in theIntel Documentation I have for them.
For that matter I cant find Lib$ in Google....
Renee
reneeculver
I feel that Microsoft has messed up it's Help in VS version 10 and VS SP1. Obviously SP1 is an improvement,but one can no longer copy from it therefore is largely useless.
For Intel, it found sleep when I searched for it as a pdf file. Since I had what I needed I did not persist in search. I got a .PDF Intel Users and reference guide on the net and that works. The help doesn't as the Find doesn't work at allin VS, with Intel material.
I find that I like books with pages. By the the way, the Unix information is useless and is noise as far as I'm concerned.
Renee
reneeculver
Hmmmm, After applying the latest set of patches, Find works OK on the PDF file I also have the latest PDF patches.
Renee
psantos
reneeculver,
You probably have some problem with VS10. I'm using VS10 and I have access to Composer XE documentation using the help tab. I see the doc's through Microsoft help viewer. I also have a search tab.
Pedro
mecej4
For a good reason. In all probability, they do not exist and will not exist on any OS other than VMS.
Functional equivalents for some LIB$ functions may exist, but these are not part of the Fortran language and portable code will not reference them. As the years pass, it will get harder to dig up even information on what those routines were supposed to do, let alone working ports.
reneeculver
AMEN.... I have been having trouble with the documentation! I use a PDF I found on the net.
Thanks you.
Renee
reneeculver
Thanks you.
Renee
reneeculver
"For a good reason. In all probability, they do not exist and will not exist on any OS other than VMS.
Functional equivalents for some LIB$ functions may exist, but these are not part of the Fortran language and portable code will not reference them. As the years pass, it will get harder to dig up even information on what those routines were supposed to do, let alone working ports"
VMS was the best OS ever made, bar none. It's a shame the we are going backwards in the OS world.
Renee
Renee,
I was not implying that Intel Fortran had LIB$ routines. I was commenting on your remark about VMS $HIBER and not having "sleep" on VMS, pointing out that yes indeed you did.
reneeculver
Sleep should not be confused with $hiber. With $hiber, a thread was subject to asynchronous wakeup. Nothing will wake up Sleep because it is purely synchronous where $hiber was asynchronous. There is a day and night difference between Lib$sleep and $hiber. If I'm not mistaken, the wakeup to $hiber was delivered at ASTDEL (IPL 2) and was relatively fast.
Sleep is clumsy; $hiber was refined. Unix was largely a synchronous operating system, which is why Unix programmers do not understand what we're talking about and people think Sleep or Lib$sleep is OK. It's not.
I used $Hiber in the Shadow Serverfora reason which was that it was asynchronous. I never used Lib$sleep because of it's synchronicity.
Renee
