29429 Discussions
Slight change in behaviour of allocated intrinsic function in IFX
Andrew_Smith
Valued Contributor I
If a derived type a has an allocatable component b, and b also has an allocatable component c, then allocated(a%b%c) with IFORT returns .TRUE. if either b or c is not allocated. In IFX, it fails if b is not allocated. I suspect its closer to the standard now. But now I have to check each in turn and because Fortran does not shortcut the logical expressions once one fails, we have to now use separate if statements to replicate the old behaviour.
if (allocated(a%b)) then
   if (allocated(a%b%c)) then
Devorah_H_Intel
Can you please provide a test case for what you are observing? Our internal testing doesn't confirm the behavior you are describing.
Andrew_Smith
Hm, you are correct, it fails for both compilers with my reproducer. My actual code had been working. Can you try an older compiler? Here is the reproducer:
module mod1
    implicit none
    type c
      integer dummy
    end type
    type b
      type(c), allocatable :: y
    end type
    type a
      type(b), allocatable :: x
    end type
end module
program test
   use mod1
   implicit none
   type(a) v
   print *, allocated(v%x%y)
   pause
end
Devorah_H_Intel
Thank you, @Andrew_Smith
