Slow WRITE
Intel_C_Intel
I have a model that outputs a diagnostic file. If I open the diagnostic file like this:
	OPEN ( UNIT = OptimDiagnosticLun,
	1	FILE = TempFileName,
	1	STATUS = 'UNKNOWN',
	1	ACTION = 'WRITE',
	1	IOSTAT = ios )
the model takes 14.04 seconds to run and produce the output file.
If I open the file like this:
	1	IOSTAT = ios )
the model takes only 0.67 seconds to run and produce the output file.
Why?
Compiler name and version?
Nothing comes to mind offhand... Is it actually the WRITEs that are slow? What if you comment out the WRITEs from both versions?
Steve
Intel_C_Intel
Sorry Steve - I always forget that, CVF 6.6B on Windows 2000.
I'm actually comparing a new version with an old version. I expected the new one to be quicker, was using diagnostics to check the results and was surprised to find I was wrong. The above difference is the only change that has been made relating to diagnostics, so I don't think commenting out all the WRITEs would show anything. Besides which, there are hundreds of them spread over tens of files! I noticed this because the new version WAS faster when I turned the diagnostics off completely.
I did some more tests this morning with full diagnostics:
Old version: 17 iterations in 5.70s
New version with ACTION='WRITE': 11 iterations in 106.5s
New version without ACTION='WRITE': 11 iterations in 2.31s
(all producing 5.57 MB of diagnostic output)
I did notice that with ACTION='WRITE' hardly any processor time was being used by my process (usually it grabs as much as it can).
The file is being written to a UNC path on our network.
ACTION='WRITE' was added to prevent crashes when trying to write to read only files, and the only explanation I can think of is that it is adding some kind of over head to every WRITE statement (a 'writeability' check?)...
Dan
Intel_C_Intel
Steve, I tested some more and it seems to be a problem with network writing. I used the following test program to demonstrate:
!  PROGRAM: FWriteTest
	PROGRAM FWriteTest
	IMPLICIT NONE
	! Variables
	CHARACTER	FileName*260
	INTEGER*4	i, ios
	REAL*8		start, fin, time
	! Body of FWriteTest
	!FileName = 'C:TempFWriteTestTestOutput1.txt'
	FileName = 'SRV-OSPREYDEVTestOutput1.txt'
	OPEN ( UNIT = 1, FILE = FileName, STATUS = 'UNKNOWN', ACTION = 'WRITE', IOSTAT = ios, BUFFERED = 'YES' )
	CALL CPU_TIME(start)
	DO i = 1, 100000
		WRITE (1, *) 'All work and no play makes Jack a dull boy.'
	END DO
	CALL CPU_TIME(fin)
	time = fin - start
	WRITE (1, '(A, G10.5)') 'Time:', time
	CLOSE (UNIT=1)
	!FileName = 'C:TempFWriteTestTestOutput2.txt'
	FileName = 'SRV-OSPREYDEVTestOutput2.txt'
	OPEN ( UNIT = 1, FILE = FileName, STATUS = 'UNKNOWN', IOSTAT = ios, BUFFERED = 'YES' )
	DO i = 1, 100000
	END DO
	CALL CPU_TIME(fin)
	time = fin - start
	CLOSE (UNIT=1)
	END PROGRAM FWriteTest
At first I didn't have the BUFFERED statement, and it took 9.3s to write with ACTION='WRITE' and 0.5s to write without. Buffering helps, bring both times down to about 0.1s, but it is still slightly faster without the ACTION='WRITE'
Intel_C_Intel
PROGRAM FWriteTest
IMPLICIT NONE
! Variables
INTEGER*4	i, ios
DO i = 1, 100000
END DO
CALL CPU_TIME(fin)
time = fin - start
CLOSE (UNIT=1)
DO i = 1, 100000
END DO
CALL CPU_TIME(fin)
time = fin - start
CLOSE (UNIT=1)
Ah, the file is on a network share. You didn't tell us that originally!
I don't know why ACTION='WRITE' makes a difference, but I'm guessing this causes the Windows file system to do something different. CVF just passes that as part of the arguments to CreateFile.
Steve
Intel_C_Intel
We have noticed slower network access with CVF (6.6 on NT and XP) but have not been able to trace it - we cannot be sure it's CVF that is the problem though.
