Slow compilation
Stupak__Richard
Hi all,
I have some mixed language DLL (c++ & fortran). I am using WIN7 with VS2015 and Intel fortran compiler 2016, when i try to compile it, it takes like 1 minute for one fortran file. When i compile it on WinXP VS6 and visual compaq fortran it takes like 1m for whole DLL.
When i am compiling other applications (pure c++) it goes fine.
Do you have any idea if there is some problem in settings of intel fortran compiler??
Richard
Johannes_Rieke
New Contributor III
Hi James, I had multiple files in 'C:\Program Files (x86)\Common Files\Intel\Licenses' causing this issue. There should be normally only one file *.lic. Further list your system variables with 'SET | more' or 'set>my_sys_vars.txt' in a command shell. If you find 'LM_LICENSE_FILE' set, google how to remove system variables. You might need administrator rights.
Steve_Lionel
On Windows 10, right click "This PC" and select Properties. Click "Advanced System Settings". On the new screen, click "Environment Variables" at the bottom. Here is where you can edit system environment variables.
I don't think Linux has the concept of system environment variables.
SL00
Dear all,
I am now experiencing the same long compilation time as well.
real 13m49.774s
user 8m10.299s
sys 0m5.653s
Here is the product information,
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.1.163 Build 20171018
Configuration of my laptop,
Memory: 16GB
Processor: Intel® Core™ i7-5600U CPU @ 2.60GHz × 4
OS type: 64-bit
Disk: 250GB SSD
My code is written in pure Fortran and has 332,333 lines.
Any idea about this?
Cheers,
Xiangyu
andrew_4619
Is this slow speed in relation to a change in compiler? What do you uses before and how long was a compile typically?
Your 332,333 lines of code, is this one file or many files? In have found that size of complexity of a file increases compile time in is disproportionate manner in some cases.
But there are many possible causes and we do not have much to go on from your info.
