Slow editor response
abhimodak
Quite often the Visual Studio editor response slows down due to Fortran Integration --- Compile 19.0 update 5 (package 281) with VS2019. Eventually (sometimes) there is a pop-up (from the VS), indicating one of the extensions (Fortran IDE) is slowing things down.
There have been posts earlier indicating turning off intellisense and other options.
These options/tools are very useful; hence, what are the latest recommendations for usage of editor extensions? It does get excruciatingly slow; to the point that one is forced to close VS instance and open again. There appears some delta-time after which whatever is running in background/listening to the edits 'get tired'.... and the editor becomes useless.
Abhi
andrew_4619
Yup, the problem has been around for years. I never found any workaround, I got to live with closing and opening again at the first sign of the issue. I am not seeing this problem with VS2022 but that has other problems that are maybe worse for me (debugging watching). I am hoping the VS integration issues on VS2022 get fixed soon.
Devorah_H_Intel
@abhimodak  @andrew_4619
Do you still experience slowness issue with VS2022? If yes, what version of VS2022 and could you provide a VS solution for us to reproduce and investigate the cause.
JohnNichols
Valued Contributor III
With the latest VS 2022 Preview, those old issues seem to have gone, they come back if I make a mistake and use an older VS.  I keep the older ones for other mistakes and Fortran is fast.
JohnNichols
But if you go that route, do not add any Windows SDK beyond those that come with an original install, otherwise you will spend a few hours fixing the issue with IFX.
andrew_4619
I am using Microsoft Visual Studio Community 2022 (64-bit) Version 17.0.5 and latest OneAPI. The problem has not gone away and was the same in VS2019 and VS2017 previously.  I will try to make a reproducer that doesn't involve my actual code. The main issue for me is submodule interface  files where we have a lot of interfere module subroutine end module subroutine end interface blocks. After a short while these become impossible to edit as every keystroke involves a long wait whilst  it rescans the document(s) or whatever it does. The answer is to close VS and reopen and then it will be OK for a short time. Editing other files isn't an issue.
JohnNichols
Microsoft Visual Studio Community 2022 (64-bit) - Preview
Version 17.8.0 Preview 6.0
I use this all day every day and have no editor problems.  It will coexist with all the others and is a simple load.
But an example we can test is a lot better than anything.
andrew_4619
@Devorah_H_Intel  I created a solution and project attached as a zip slow-ves-edit.f90 is included but not called is is just a generator for the other three source files which consist of a module with 500 interfaces and a submodule with 500 very boring subroutine named rr1 through to rr500. Anyway open the project and have a play and within a vary short period the _if.f90 becomes very slow. Hit enter for a new line and wait a few seconds before you can do the next thing. The more you edit the longer the wait gets. Enjoy.
module slow
implicit none(type, external)
interface ! RR1
    module subroutine RR1(A, B )
        real :: A, B
    end subroutine RR1
end interface
interface ! RR2
    module subroutine RR2(A, B )
        real :: A, B
    end subroutine RR2
end interface
interface ! RR3
    module subroutine RR3(A, B )
        real :: A, B
    end subroutine RR3
end interface
interface ! RR4
    module subroutine RR4(A, B )
JohnNichols
I see your point, I wonder what is happening, I have many f90 files that long and they are not slow.
Interesting and frustrating.
Sorry old chap, no idea.
@Barbara === why does your name not pop up in the list of users,  but even on the latest preview it is a dead dog on this code.
andrew_4619
yes John the length of the file is not the trigger  it is the structure of the file. I also not the folds on interface and subroutine often become foobahed  from time to time also which requires closing the solution. Maybe there is linkage....
JohnNichols
Edit it in NOTEPAD++ or VEDIT or any decent editor, even SIDEKICK 95.
andrew_4619
Nup, I use Notepad++ for many things but for a large source project actual editing is a small part of the activity,  navigation around the project , links from errors to source file lines etc  the integrated IDE improves productivity in many ways.
JohnNichols
Devorah_H_Intel
module slow
interface ! RR1
        real :: A, B
    end subroutine RR1
end interface
interface ! RR2
        real :: A, B
    end subroutine RR2
end interface
interface ! RR3
        real :: A, B
    end subroutine RR3
end interface
interface ! RR4
Thank you @andrew_4619 for putting together the test case for us
I will test and pass it along to engineering for further investigation.
Devorah_H_Intel
module slow
interface ! RR1
        real :: A, B
    end subroutine RR1
end interface
interface ! RR2
        real :: A, B
    end subroutine RR2
end interface
interface ! RR3
        real :: A, B
    end subroutine RR3
end interface
interface ! RR4
Thank you again for the solution. The fix will be available in 2024.1 Intel HPC Toolkit release.
andrew_4619
oooooo! Thank you, I will look forward to that update!
This problem does my head in!  I had to restart VS about 10 times yesterday and each time my blood pressure goes up a click !
JohnNichols
Breathe, deep breathing and relax.   Feel the Intel Fortran flow though your mind.
Nirvana awaits you in 3 months or so, you can last that long.
Devorah_H_Intel
@andrew_4619 we are able to reproduce the issue with your reproducer. The engineering team are working on the fix.
andrew_4619
Thanks, I think there used to be several things that caused editor problems and I think some have been fixed / gone away. There may be other issues but with his one a trigger was evident.  I will note that if the reproducer had less routines the problem seems to build up slowly with working and then hit a tipping point where it rapidly becomes unusable.
