29375 Discussions
Source code browser in IVF 10.0 and searching project files
Kalgutkar__Rajdeep
How does one search for text in multiple fortran source code files in a single project when using VS2005 with IVF 10.0?
Also, Is the source code browser enabled in IVF 10.0. I remember some discussions here about it being enabled in "future" versions.
Thanks!
Use the search tool in the toolbar - you can search the entire solution or specific folders.
The Source Browser is still not available, but it's still something we'd like to do.
Kalgutkar__Rajdeep
Thanks for the source code browser update.
When I try to click the find button on the toolbar or via Edit -> Find and Replace -> Find in Files, VS2005 simply ignores the command and my cursor goes to where it was in the Fortran file. It works just fine in VS2005 C++ so what's happening here?
I don't know - I've never seen that behavior myself nor do I recall seeing it reported by others. I suppose you could try doing an uninstall and reinstall of the Intel Fortran Integration into Microsoft Visual Studio and see if it helps. If not, please file a report at Intel Premier Support.
Kalgutkar__Rajdeep
OK, I'll remove and reinstall only the IVF integration in VS 2005.
Hopefully that works. Else I'll send a note to Premier Support
Kalgutkar__Rajdeep
OK, I sort of figured what was wrong... Basically, when I reset my Visual Studio settings Sad smiley [:(] under Tools -> Import and Export Settings, I am able to call up the Find in Files and related dialog boxes again. Not sure why it broke in the first place...
http://forums.microsoft.com/MSDN/ShowPost.aspx?PostID=798652&SiteID=1
Interesting - thanks for telling us the solution.
John4
Valued Contributor I
I had the same problem once before, and it seems to me that it's related to an inconsistent behavior between the close button in the Find/Replace widget (the X) and the Esc key.
Installing the Service Pack 1 solved the problem for me.
