Sparse Matrix storage
Adrian_F_1
We have many 2 and 3 dimensional arrays which are allocated based on the size of the problem.  We are running into memory overflow errors with large problems.  These arrays are very sparse so I only need to store the non-zero elements.  Is there a sparse matrix handler in Intel Fortran I could use, preferably with the same syntax, eg:
a(i,j,k) = 123.456
or xyz = a(i,j,k)
to save replacing the occurrences in the code?
Adrian
TimP
Library support for sparse matrices is included in the MKL library provided with ifort. Open source versions of that and other libraries are available.
